Author Topic: Its is normal?  (Read 1035 times)
Yoni159
Its is normal?
« on: September 23, 2022, 07:31:57 PM »
Re: Its is normal?
« Reply #1 on: September 23, 2022, 08:52:14 PM »
My opinion is no in both cases. Two DT300i machines those rubber bushings were very tight with no wiggle anywhere. R & R all those bushings ASAP (real soon!).
Yoni159
Re: Its is normal?
« Reply #2 on: September 23, 2022, 09:33:12 PM »
i bought its like this second hand 3 yeras ago. I dont know...
mousejunks
Re: Its is normal?
« Reply #3 on: September 23, 2022, 10:16:59 PM »
The first video the rubber bushing is a bit loose but you can tighten or replace the bushing. The second video it's wobbling on the centre stand, not an issue.
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
Re: Its is normal?
« Reply #4 on: September 23, 2022, 11:15:43 PM »
I looked at the second video again and could see the clearance between the air filter enclosure change quite a bit as he was shaking the back wheel sideways. I have an idea the straight line ride is squirrelly to be blunt.
Re: Its is normal?
« Reply #5 on: September 24, 2022, 03:50:19 PM »
Swing arm bushings----replace period.  used to be problem with Japanese bikes---really screws up handling.   Your case, bike age and miles(km's)
