Author Topic: What is this problem?  (Read 1540 times)
Yoni159
« on: September 26, 2022, 07:35:57 PM »
Its not from the front wheel its coming from above
Re: What is this problem?
« Reply #1 on: September 26, 2022, 07:50:52 PM »
Looks like front wheel bearings are missing some balls....
Yoni159
« Reply #2 on: September 26, 2022, 07:52:58 PM »
its not from the wheel.
« Reply #3 on: September 26, 2022, 07:55:03 PM »
Head bearings gone?
« Reply #4 on: September 26, 2022, 08:02:07 PM »
Big head bearing nut loose. Maybe to fix by turning it with a proper tool. Mostly thread demaged. But only to be terminated when some fairing is off.
Yoni159
« Reply #5 on: September 29, 2022, 04:12:20 AM »
It is dangerous to ride like this maybe more 300-400km i dont havr any money to fix it right know. Maybe i can fix it alone ?
« Reply #6 on: September 29, 2022, 06:43:08 AM »
A quote from someone who appears to know more than me:
“ They could just be loose. If you don't get them tightened up, they WILL wear out quickly since they are getting hammered over every bump.
If you elevate the front end and tighten the bearings like the shop manual says, the bars will "index" if the races are shot. What I mean is the bars will turn about 10 degrees and stop, require more effort, then stop again so your steering feels notchy. This will eventually affect handling in a very bad way.
I would see if they behave after tightening. If they don't, I'd replace them in a heartbeat.”
My advice? Take the bus until you can afford the repair.
Yoni159
« Reply #7 on: September 30, 2022, 02:57:02 AM »
Which part in need to tighten?
https://ibb.co/cvXhDk3
https://ibb.co/2FLVXSB
Yoni159
« Reply #8 on: September 30, 2022, 02:57:38 AM »
« Reply #9 on: September 30, 2022, 04:37:39 AM »
Honest answer?  I'm out of my comfort zone now.  Presumably it couldn't hurt to check both, but hopefully someone more skilled than I (Crossbolt?  Ruffus?) will pitch in and advise.
Yoni159
« Reply #10 on: September 30, 2022, 08:47:46 AM »
someone here was right i checked it very good and its front wheel bearing. I glad it is because its cheaper to replace. Something strange is i replaced them 2 years ago
« Reply #11 on: September 30, 2022, 08:53:25 AM »
Glad you got to the bottom of it!
« Reply #12 on: September 30, 2022, 10:17:24 AM »
the lower or the upper?
The tightening of the upper tightens both.
« Reply #13 on: September 30, 2022, 02:21:37 PM »
Yay!  You were right first time Karl.
« Reply #14 on: September 30, 2022, 07:59:31 PM »
Thanks, I needed that!
