Author Topic: KYMCO 300I 2008 Problem with instrumental panel  (Read 2571 times)
pinosan
« on: October 18, 2022, 08:47:08 PM »
Hi, I have a Kymco xciting 300i, no longer works the instrumentation, the temperature sensor after a few minutes marks full scale, battery light on, gasoline sensor marks full scale etc.  I also changed the whole electrical system, but the problem remains, what can be?
Thank you
Re: KYMCO 300I 2008 Problem with instrumental panel
« Reply #1 on: October 18, 2022, 09:51:17 PM »
Thank you
Whoa! What does "changed whole electrical system" really mean?
pinosan
« Reply #2 on: October 19, 2022, 08:25:01 AM »
yes i replaced the whole electric system but without success
has it happened before? have you solved'
« Reply #3 on: October 19, 2022, 12:25:19 PM »
There may be a language problem here, but my question "what does that mean" is still unanswered. Does it mean you replaced EVERY electrical/electronic component AND the wiring harness? Every switch and relay?
pinosan
« Reply #4 on: October 19, 2022, 02:57:24 PM »
Sorry for my English, but I’m Italian.
I changed all the wires in the system, but the problem still persists. I didn’t change any other instruments, only the cables
« Reply #5 on: October 19, 2022, 03:13:41 PM »
Okay, I understand. You changed the entire wiring harness, correct? Factory part? No differences in colors of wires?
pinosan
« Reply #6 on: October 19, 2022, 04:02:34 PM »
pinosan
« Reply #7 on: October 19, 2022, 04:09:38 PM »
I think it’s a common problem, I saw on sale on the internet a Kymco 500 (2008), with my own problems
« Reply #8 on: October 19, 2022, 05:45:43 PM »
I think the problem that is common is a voltage regulator on the instrument panel breaks and gives bad readings. It can be replaced but the instrument panel has to be sawed apart and the printed circuit board removed to get at the regulator. An electronics technician like a cell phone repairman could do this.
pinosan
« Reply #9 on: October 19, 2022, 09:23:15 PM »
if this is the problem, I think the best solution is to find a new instrumental panel (second hand)
thank you for your help
best regards   Giuseppe
« Reply #10 on: October 19, 2022, 09:48:14 PM »
That sounds good. You already got burned by replacing the wiring. This can't hurt as much as that! Keep us advised how this goes...
« Reply #11 on: October 21, 2022, 08:28:14 PM »
@pinosan, salve
visto che sei in Italia, vedi le offerte su subito.it, ci sono molti ricambi Kymco disponibili.
Since you are in Italy, see offers in subito.it,  there are lots of  Kymco spares available.
