Author Topic: HELP valve location super 9  (Read 849 times)
OT613
« on: October 22, 2022, 08:53:06 PM »
Hello i am trying to get my super 9 running first replacing driveshaft for water pump then i blew head gasket from heat b4 i fixed coolant system replaced the gaskets and now its still having a hard time valve adjustment is what i can see everyone says to do but i cant find anything on my scooter even close to a valve please help where are the valves on the super 9 if there are any and what else could be wrong its slow and hard to start also heat light comes on right away b4 its hot not sure why i don't know how to bleed cooling lines on super 9 so that as well please any help is very appreciated.
Re: HELP valve location super 9
« Reply #1 on: October 22, 2022, 08:59:30 PM »
Is your scooter a 2 stroke?
« Reply #2 on: October 22, 2022, 10:14:40 PM »
whoops, had to look that one up, yes, it's a 2 stroke...so you don't have valves in your engine!
OT613
« Reply #3 on: October 23, 2022, 02:42:42 AM »
Thank you so much. like i said i do houses buy have learned a lot over the last few weeks working on these but still need help often. so with no valves is there anything else i need tp do to maintain? it is hard to start and bogs out at times. also made a head gasket from cardboard and now i get a slight knock from cylinder guessing i made it slightly bigger with using a larger material as gasket can anyone tell me if this is an issue or will cause issues. and lastly i have it where it runs but the heat light comes on right away as so as i turn it over so its not hot its just turned on i just replaces the drive shaft in cooling pump its all looks good but still warrning light any ideas please help
souzamoto
« Reply #4 on: October 23, 2022, 05:20:40 AM »
No disrespect but, you need to not work on your scooter. Find a friend that has some knowledge to help you.  You cannot make a head gasket out of cardboard.
« Reply #5 on: October 23, 2022, 12:40:53 PM »
Ask in an auto parts store for a sheet of automotive gasket material. Cut one from that, not cardboard.
« Reply #6 on: October 23, 2022, 01:52:21 PM »
head gaskets are usually some composite of metal and gasket material, as opposed to all the other gaskets in the engine. A head gasket is a specific item to an engine..OP should buy the OEM gasket. See 12251 in pic
souzamoto
« Reply #7 on: October 23, 2022, 06:25:28 PM »
Finally, someone gives correct information
« Reply #8 on: October 23, 2022, 06:39:26 PM »
You had the first opportunity to describe a proper head gasket....
