Author Topic: 50cc agility RS cdi derestriction  (Read 10895 times)
Rianna
Re: 50cc agility RS cdi derestriction
« Reply #15 on: November 27, 2010, 02:37:01 PM »
Ha! Okay, Jas. Glad ya found it! :D
oswaldters
« Reply #16 on: November 27, 2010, 03:02:53 PM »
Have you seen the pictures/info from this thread before?
http://kymcoforum.com/index.php?topic=455.msg5543#msg5543
Should be same cdi as yours.
Rianna
« Reply #17 on: November 27, 2010, 03:05:16 PM »
Alright! You got your pictures posted!! Knew you could do it, Jas. :)
oswaldters
« Reply #18 on: November 27, 2010, 03:09:49 PM »
Did you read the posts in the link above?
That should explain it - sound like you just need to unplug one of the wires.  So no need to cut which is great because you can always plug it back in.
Hard to tell from your pictures, but are some of the wires pink?
Rianna
« Reply #19 on: November 27, 2010, 03:20:59 PM »
Hiya, Jaspi, you could just pull one wire out and take a little test run and come back and tell us how it did, okay? Don't cut anything. :)
oswaldters
« Reply #20 on: November 27, 2010, 03:23:22 PM »
Derestricting the cdi will give you some extra revs, but not make a huge difference.  And Rianna is right, just pull out one of the pink wires - don't cut anything.
You really need to derestrict the drive boss to give you that extra top end.
Rianna
« Reply #21 on: November 27, 2010, 03:26:52 PM »
You ever unplug your television or toaster, Jas. Just unplug. Try that then plug it back in.
Rianna
« Reply #22 on: November 27, 2010, 03:27:29 PM »
I think you can do it! ;D
Rianna
« Reply #23 on: November 27, 2010, 03:35:55 PM »
You are humorous so I will humor you. Okay here is what you can do. You can Grab the wire in your hand and move your hand to the end of the wire and look at the end to see how it is connected. Then you can decide how to disconnect it on your scoot. Let's start with that. ;)
oswaldters
« Reply #24 on: November 27, 2010, 03:39:23 PM »
You'll probably need a small blade of some type of get in there and pop the wire out.
A small blade flat screwdriver would do it - but in your case a small knife is probably more your style.
Just slip the end of the wire out of the connector and tape it off (the wire that is).
Rianna
« Reply #25 on: November 27, 2010, 03:40:29 PM »
And Jaspi, please don't have the key in the ignition. Just in case.
Rianna
« Reply #26 on: November 27, 2010, 03:51:09 PM »
Love ya, Jaspi. It's been fun messin' with ya...:D
oswaldters
« Reply #27 on: November 27, 2010, 07:30:45 PM »
Yeah, it might just be a trial and error kind of process.
That's why you want to be careful when you pull out that pink wire...
Rianna
« Reply #28 on: November 27, 2010, 08:33:41 PM »
Hi, Jas. Have you taken the pink wire out? How many pink wires do you have?
Rianna
« Reply #29 on: November 27, 2010, 09:04:06 PM »
Hi, Jaspi! Wow! Long time no see! You was gone a long time! Oh MY! You better warm up before going back out there! You might need that there body part for something!
Yank one of them wires out of there, baby! Then you be ready to roll! ;)
