Author Topic: Seat lock stuck  (Read 720 times)
jan.strydom
Seat lock stuck
« on: November 21, 2022, 07:50:10 AM »
key turns but seat wont open...stuck on right hand side - have tried everything....
NorWeWa
Re: Seat lock stuck
« Reply #1 on: November 21, 2022, 05:32:35 PM »
Don't have the 500, have the 300.
Can you access the lock cable from the key switch? On the 300 you can see the cable from under the front and give it a pull.
Art
stuo
Re: Seat lock stuck
« Reply #2 on: November 21, 2022, 08:21:54 PM »
I had the same problem on my DT300; it had two seat locks, which is overkill, so I removed the bracket on the seat pan for the lock that didn't trigger the light switch.
2009 GV 250
NorWeWa
Re: Seat lock stuck
« Reply #3 on: November 21, 2022, 08:53:17 PM »
I attached zip ties to the latches which hang down under the plastic, which I can pull to release the latches.
Art
wymple
Re: Seat lock stuck
« Reply #4 on: November 26, 2022, 02:51:27 AM »
There were 2 latches under my seat. Totally unneeded. I took one off.
NorWeWa
Re: Seat lock stuck
« Reply #5 on: November 28, 2022, 05:47:17 PM »
I hope the OP got the seat unlatched.
