Author Topic: Bearings kit  (Read 1928 times)
Re: Bearings kit
« Reply #1 on: November 27, 2022, 07:12:49 PM »
Hard to tell, for AMAZON guy uses different sparepart #'s than KYMCO on its sheet.
Though I guess all People models are pretty much the same.
If you got time, take them out, see a tech supplier and buy there.
Re: Bearings kit
« Reply #2 on: November 28, 2022, 03:13:30 AM »
I found that I can buy bearings for my Kymco scooter by referring to the kymco parts listing. Often the bearing size is listed there next to the Kymco part number and the price.
I then go to ebay and buy a nice Japanese bearing in the proper size and type from a dealer with a great ebay rep.
fest
Re: Bearings kit
« Reply #3 on: November 30, 2022, 11:12:15 PM »
Thanks for your reply. Will let you know once i get them if they fit. I got them from another ebay seller but look similar like in that above link.
fest
Re: Bearings kit
« Reply #4 on: June 13, 2023, 10:58:09 PM »
After technical difficulties, I am finally able to update the post.
I've managed to replace the bearings in my steering column. Not an easy job for sure. But the bike feels very different now.
https://ibb.co/YyqvW1t
https://ibb.co/vZyksNP
I also got Steering Stem Bearing Race Removal Tool for Yamaha TRX850 1996-2000, and made the job super easy.
https://ibb.co/Wc90FdT
I highly recommend that you check the bearings, during winter when you are not riding. As there is a lot to remove. You will also need a tool to remove the handlebar too. Cyclepedia manual will come in handy too.
Faber32
Re: Bearings kit
« Reply #5 on: June 24, 2023, 08:08:33 PM »
I'm sorry I'm reading only now this post. I've replaced the bearings on my Gti 125 and the bearings are the same of your Gti300 if I remember well. I used aftermarket ones even if different from genuine ones but they work fine for now.
