Author Topic: kymco like 150i gas leak  (Read 784 times)
mojorising
« on: December 14, 2022, 07:44:30 AM »
finally found the source of my gas leak
https://photos.app.goo.gl/DMDM5XbUsDmRNWTdA
i adjusted my valves and when i started the bike i noticed gas pooling on the top of the tank. Any ideas how this could have happened? Im thinking about using some silicon to seal it.
Re: kymco like 150i gas leak
« Reply #1 on: December 14, 2022, 11:42:14 AM »
Pretty sure there was a recall on this leak up by the top of the tank.
edit-----
https://kymcousa.com/wp-content/uploads/2019/11/KYMCO-Like-150i-puplic-announcement-letter-like-150.pdf
This sounds like a job for the dealer.
« Last Edit: December 14, 2022, 11:49:47 AM by Stig / Major Tom »
« Reply #2 on: December 14, 2022, 01:32:19 PM »
excellent catch, Stig!
mojorising
« Reply #3 on: December 15, 2022, 06:12:40 AM »
wow you guys are the best!!! thank you so much
mojorising
« Reply #4 on: December 15, 2022, 06:19:01 AM »
i got one more for you guys! Could you help me find the OEM exhaust gasket? 2018 Kymco Like 150i.
i tried replacing with a 33mm copper gasket but the seal isnt good. if i cant find the OEM ill try the gasket maker
« Last Edit: December 15, 2022, 06:20:49 AM by mojorising »
« Reply #5 on: December 15, 2022, 12:22:32 PM »
Can you measure the original?
Lots of scooter gy6 gaskets on ebay.
Call your dealer??
Good luck!
mojorising
« Reply #6 on: December 21, 2022, 07:15:02 AM »
the pick is of the original. i think the one i replaced it with is just a little too thin. i just got some thicker ones that look too big though hahaha. i think i can make it work though no worries. The gy6 ones are too small though.
Anyways I'm taking the scooter to a dealer tomorrow morning for the repair. Definitely curious to see if they'll just put some silicon over the wires or replace the entire pump. I'll definitely update you guys after its all said and done.
