Author Topic: 2017 utv450i  (Read 594 times)
dse186
2017 utv450i
« on: January 16, 2023, 11:13:10 PM »
2017 uvx450i has no spark! Changed coil not the problem, fuses are good. When  turning key over I noticed that the shifter was lighting up the park and low light at same time and low light stays on no matter what gear. I unplugged Ecm and and it goes back to normal and does the same thing when plugged back in. So is it a good possibility the ecm needs replaced?
airshot
Re: 2017 utv450i
« Reply #1 on: January 17, 2023, 01:31:48 AM »
Cant say what all has changed on the 2017 models, but on my 2015, the switches that activate the lights for the shifter are inside the xase where the shift mechanism goes. On my unit, adjusting the linkage can make those lites come in or go off deoending on position of shifter.  On mine, when the reverse lite comes on, my machine is not actually full reverse and if I adjust for full reverse engagment, then the light won't work...  I woukdn't think the ecm would control this, however....what has changed over those two years??
dse186
Re: 2017 utv450i
« Reply #2 on: January 17, 2023, 02:43:12 PM »
I have no idea what has changed between years. I don’t know if a bad neutral safety switch would cause no spark and no power to fuel pump I’m assuming it’s the ecm
