Author Topic: Kymco agility petcock replacement  (Read 741 times)
Glenn67
« on: January 22, 2023, 06:15:52 AM »
Hello, would anyone know if you have to take the fuel tank off to replace the petcock on a 2008 Kymco agility 125?.. Thanks
Re: Kymco agility petcock replacement
« Reply #1 on: January 22, 2023, 03:03:09 PM »
it appears to be the standard petcock where you unscrew it from the bottom.
Glenn67
« Reply #2 on: January 22, 2023, 08:32:53 PM »
Thanks for the diagram.. just wasn’t sure if there was enough room under the tank..
« Reply #3 on: January 22, 2023, 10:57:55 PM »
some scoots are no problem, others you may find you'll need to pull the back wheel or some plastics off to get adequate access.
aschrauth
« Reply #4 on: January 24, 2023, 01:53:32 AM »
Just replaced mine because the diaphram went bad inside the petcock causing the engine to suck in fuel both ways causing a flooding issue. When taking the old one out I removed the bottem plastic faring whitch allwoed me to screw in the new one. However, it is possible to do it with the bottem faring on.
Kymco 125cc
Wolf Rx50 BBK 80cc
Glenn67
« Reply #5 on: January 24, 2023, 10:50:54 AM »
Yes mine is doing the same thing.. it took me a while to work it out, hopefully it works!.. Thanks for the info..
