Author Topic: 2018 Kymco Like 150i  (Read 804 times)
mojorising
« on: January 25, 2023, 06:26:40 AM »
So i was doing a valve adjustment and i stripped the inlet on the cylinder. Whoops. Rode it anyways and the bolt popped out while riding and leaked oil. going to fix the inlet but i lost the bolt. Anyone know where i can order one? This is the valve cover bolt
Re: 2018 Kymco Like 150i
« Reply #1 on: January 25, 2023, 01:19:37 PM »
not sure where you are located but the default answer is your local Kymco dealer. There are also online parts sources but you'll want to add your location / country.
« Reply #2 on: January 25, 2023, 07:16:48 PM »
+1^
« Reply #3 on: January 27, 2023, 07:16:08 PM »
@mojorising, welcome here!
Looks to me being one of this four bolts holding  your valve cover.
You said one of this threads is stripped:
Okay, no big deal:
-buy a 6mm HELICOIL repair set (online shops sell that for about €15,-)
-read its instruction and fix this thread
-buy simply a few  bolts M6x50 in your hardware store
- get a new valve cover gasket
- put valve cover, gasket on it and bolt it down with your newly purchased M6x50 bolts...voilà
« Reply #4 on: January 28, 2023, 01:54:50 PM »
Okay, no big deal:
He said he lost the bolt.  A kymco dealer should be able to get him a new one but I doubt that any dealer would have one in stock so it may take a while to get one.
« Reply #5 on: January 29, 2023, 08:48:31 PM »
@klaviator, yes,  I read he lost one of this bolts.
Measure is M6x50mm and its available in any hardware store which stocks metric bolts.
This additional shims and o-ring are not a part of this bolts.
To screw this valve cover down needs four bolts as mentioned and four small-brimmed 6mm washers on it only.
JJJoseph
  • Kymco Sento
« Reply #6 on: February 06, 2023, 03:17:15 AM »
When I was an apprentice and said something like this, my boss would reply:" It's there on the floor somewhere.  Get down on all fours with a flashlight and keep looking until you find it.  It's there, somewhere, waiting for you!"
