Author Topic: Gear oil  (Read 2614 times)
Gear oil
« on: November 29, 2010, 11:44:43 PM »
has any one ever had there gear oil leak on theam. I noticed today my gear oil leaking from the drane bold.
I changed it about 2 months ago maybe just worked it self lose not sure the only way I noticed it was I seen oil on the left side of the scoots tire. not good.
oswaldters
Re: Gear oil
« Reply #1 on: November 29, 2010, 11:58:16 PM »
Had a little drip from my drain bolt once - got it tightened up and have not had problems since.
Some blue loctite is also good to use - especially since you open that bolt infrequently.
Re: Gear oil
« Reply #2 on: December 07, 2010, 07:11:51 PM »
wtf   took scoot to work today I tighted up my gear bolt about aweel ago.came out of work
and about a oz of gear oil under scoot. dame it I guess I better do something.
Re: Gear oil
« Reply #3 on: December 07, 2010, 07:22:36 PM »
just went out and looked realy good I can see gear oil leaking from a small hole above the train bold
does kymco have a over flow drain on there agilitys if you put to much in.
aokark
Re: Gear oil
« Reply #4 on: December 07, 2010, 10:09:23 PM »
My driver's manual says to fill it up to the lower edge of the hole you fill it up in... If you'd fill it over that, I guess it would start leaking if you open the bolt
Re: Gear oil
« Reply #5 on: December 07, 2010, 10:28:44 PM »
mine is leaking from a hole just to the left of the drain hole it must be a over flow for that reason.
I gues all I can do is keep a eye on it.
oswaldters
Re: Gear oil
« Reply #6 on: December 07, 2010, 11:02:02 PM »
You might want to just drain the whole thing and make sure you put in the correct amount.
If it still leaks then you'll know that overfilling isn't the problem.
Re: Gear oil
« Reply #7 on: December 08, 2010, 12:42:02 AM »
you got point there . maybe a little liquid gasket on the drain bolt just to make sure.
oswaldters
Re: Gear oil
« Reply #8 on: December 08, 2010, 12:47:29 AM »
Sounds like a plan.
Besides, you want to make sure there's still gear oil in there and it hasn't all leaked out.
Rianna
Re: Gear oil
« Reply #9 on: December 08, 2010, 01:07:30 AM »
Dang...sorry to hear about your gear oil leak there, blue. Wish I could see what hole you're talking about. I hope you get it sorted out soon and that it's nothing serious. :)
Re: Gear oil
« Reply #10 on: December 08, 2010, 02:09:38 AM »
Im thinking because I lean the scoot to the side when I put the gear oil in there is to much in it and the extra is just running out. hopefully to much won't hurt anything.
Rianna
Re: Gear oil
« Reply #11 on: December 08, 2010, 02:14:31 AM »
Yeah, I'm hoping you caught it in time and there's no problems.
oswaldters
Re: Gear oil
« Reply #12 on: December 08, 2010, 02:22:04 AM »
I'd just open the filler bolt (while on the center stand) and let any excess run out now rather than have it pushed out under pressure of running.
Re: Gear oil
« Reply #13 on: December 08, 2010, 02:48:45 AM »
that a good idea thanks osw
Rianna
Re: Gear oil
« Reply #14 on: December 09, 2010, 02:50:03 AM »
Hi, blue, you get your gear oil situation sorted out??
