Author Topic: AK550 Oil Change Interval Service Manual Question 9,000 miles?  (Read 661 times)
Luckyword
« on: February 09, 2023, 01:36:16 PM »
I've been having the oil replaced every 3,000 miles on my AK550 -- looking at the Service Manual I received with the scooter, it seems to indicate that no Oil Change is necessary at 9,000 and 15,000 miles (screenshot).
I like the idea of saving time and money -- any thoughts on the rationale for why the manual would recommend skipping the oil change interval? Do you skip this interval for your AK?
  • Central Iowa
Re: AK550 Oil Change Interval Service Manual Question 9,000 miles?
« Reply #1 on: February 09, 2023, 02:33:41 PM »
Actually your manual is the very same as my owner manual. It shows the oil and filter change interval at every 6000 miles, NOT 9000 miles and NOT 15,000 miles. Where do you see that? Your screenshot doesn't show that. Be sure you are looking at the "x 1000 mi" row at the top.
For the initial break in period the manual does show to replace the oil and filter at 600 miles, then just the oil (not the filter) at 3000 miles, then oil and filter at 6000 miles. Then to change both every 6000 miles after that. This is actually what has become normal for modern motorcycle engines. In fact, some motorcycle engines call for longer intervals AFTER the initial short intervals. So you are not skipping any oil change intervals.
BTW- the first few years of the Euro 4 versions of the AK did call for much shorter oil/filter change intervals but then changed in 2021 after figuring out how the engine was performing. Those shorter intervals were excessively short. Changing oil at shorter intervals won't hurt anything, but is not at all necessary.
I use full Synthetic 4 stroke motorcycle oil and the OEM HifloFiltro oil filter HF164 (which is the same filter used on many BMW motorcycles). I have the BMW filter tool, a cap style wrench, to make replacing the filter easy without removing ANY plastic including that bottom panel. The oil I use is certified JASO MA2, which IS a requirement for any bike with a wet clutch like the AK 550 (and all my previous GW, Burgman 650, ST1100, CTX1300, another Burgman 650). Don't use any oil that is not JASO MA or MA2 certified or you will eventually mess up the clutch.
This summer I'll be coming up on 12,000 miles so that means the next oil/filter change for mine as well as the CVT belt replacement. Kymco calls the CVT Belt the Drive Belt and the final drive belt that runs to the rear wheel is called the "Timing Belt (Drive Belt)." I already ordered the CVT belt from TBS and also already have an air filter. I usually check the air filter and then decide if it needs to be replaced. From the look of the air filter last time I checked it (6000 miles) it won't need to be replaced but that is different for everyone, where you ride, etc.
« Last Edit: February 09, 2023, 02:36:36 PM by rjs987 »
« Reply #2 on: February 09, 2023, 03:35:34 PM »
nothing is skipped, there...looks like manual calls for a few quick, early oil changes and then it changes to a 6000 mile interval.
I can't even let my car go 6K between changes with a 6 qt sump of synthetic and premium oil filter, let alone a bike with a small sump and wet clutch! I'm sure you'd be fine following the factory recommendation, but I would personally change the oil sooner or annually, if you don't ride that much.
If you really want to go down the rabbit hole of oil, visit Bob Is The Oil Guy (BITOG) forums...endless info from dedicated oil lunatics
  • Central Iowa
« Reply #3 on: February 09, 2023, 04:12:57 PM »
My 2015 Rav4 manuals only call for oil/filter changes on 10,000 mile intervals. I consider that the manufacturers have it pretty much figured how often the oil/filter need changing. Auto mechanic and motorcycle shops like to boost profits so recommend the 3000 mile intervals that were common 50 years ago. Engines have vastly improved since then and really don't need it sooner in spite of what some "oil lunatics" like to say. But as I mentioned earlier... if you want to change earlier or more often go ahead. It won't hurt anything.
« Reply #4 on: February 10, 2023, 01:58:59 AM »
There has slso been a movement in the motor industry to point to their vehicles extended service requirements,  as a selling point to new buyers.
I, for one, don't necessarily consider that to be proof of anything ....beyond 'marketing'.🙂
Luckyword
« Reply #5 on: February 10, 2023, 07:51:40 PM »
Cool, thanks for the clarifying helpful information.
I last had it changed at 6,000 miles, and so I'll switch to having it changed every 6,000 miles. So next change will be at 12,000.
