Author Topic: carb help  (Read 1924 times)
carb help
« on: December 02, 2010, 02:07:01 AM »
ok I have a nst with a gy6 engine in it its also a 50 cc runs rough in the cold im thinking of playing with the carb should I tune the carb to take more gas in or less. the summer time the scoot runs great.
oswaldters
Re: carb help
« Reply #1 on: December 02, 2010, 02:32:25 AM »
I have read that the theory is the cold air in winter is associated with  higher pressure so it throws off the air/fuel mix by adding more air into the mix.  Therefore, you would want a bigger jet to increase the amount of fuel in the mix.
Haven't tested it myself (yet), so take it with a grain of salt...
ts1
Re: carb help
« Reply #2 on: December 02, 2010, 08:56:02 AM »
I have read that the theory is the cold air in winter is associated with higher ...
density.
Rianna
Re: carb help
« Reply #3 on: December 02, 2010, 01:21:45 PM »
So...if you weren't re-jetting...you would turn the fuel mix screw to allow for more fuel intake??
Re: carb help
« Reply #4 on: December 02, 2010, 01:33:59 PM »
thank you much guys. just needed a little reasuring
Rianna
Re: carb help
« Reply #5 on: December 02, 2010, 01:42:42 PM »
Good luck, blue! Let me know how it turns out and hope it runs better. :)
oswaldters
Re: carb help
« Reply #6 on: December 03, 2010, 01:03:26 AM »
Hey blue, is the scoot running rough at idle?
Or is the problem while you are riding at speed?
Re: carb help
« Reply #7 on: December 03, 2010, 01:08:19 AM »
yes a little at idle have to keep throttle up so it well not stall out at times.sometimes when I come to a stop it stalls out.
oswaldters
Re: carb help
« Reply #8 on: December 03, 2010, 01:10:55 AM »
Sounds familiar!
Adjusting the mixture screw should help that
the other thing that I do in winter is increase the idle speed a bit as well as this has helped me with the low-idle problem.
Re: carb help
« Reply #9 on: December 03, 2010, 01:24:29 AM »
ill give it a try another thing i was going to try is a higher oct. gas
oswaldters
Re: carb help
« Reply #10 on: December 03, 2010, 01:32:58 AM »
I run 93 and I have the same symptoms once the cold weather hits.  Don't think the higher octane will help you with it.
If I warm the scoot fully before I ride, the problem doesn't occur.  Mostly it happens on the way home from work because I get impatient and take off before the scoot is really warmed (hey, dinner is waiting!)
Not so much of problem in the morning because I can just go back inside and stay warm while I let her warm up.
