Author Topic: Yager 200 won't start after short (battery dying after days)  (Read 2973 times)
GermanYager200i
« on: March 07, 2023, 03:52:53 PM »
Kymco Yager 200GTi
13.000 km on the clock
Bought a new battery in December 2022, generator/alternator checked and ok, charging voltage ok
-> all things checked in two different shops in December and February
Still, after standing on the street for 2-3 days in cold temperatures (below 5°C) the scooter won't start.
Multiple tries until battery is fully drained. I then fully charge the battery and it always starts again then.
Both shops are kind of clueless - only ideas are that the starter or starter relay are broken (but most say, that this shouldn't be the case).
This is my second Yager 200 and my 10th winter - never had these issues.
I'm hoping someone here has had the issue and can point me into the right direction.
As always, much appreciate your support!!
Re: Yager 200 won't start after short (battery dying after days)
« Reply #1 on: March 07, 2023, 05:16:53 PM »
@GermanYager200i, welcome here.
This injection based fuel and start system on your 200 gti doesn't bear very well with voltages under 10 V DC, means it will not fire up if voltage drops under this value.
So, do find the culprit:
-ignition off
-take a multimeter and put it between battery+ and  cable
- ignition on
- multimeter on ohm
- IS there is current flowing?
THIS Yager/Dink have a charging socket within the seats undertray(pls see pics), sometimes this and illumination is emptying the battery, if its switch is not closed completely.
Take the bulb out, check the 12V socket.
Pls give a feedback to learn.
EDIT: CROSSBOLTS say got me to think of this ground points at your startermotors rear end.
A corrosion there or at your fuses connectors might lead to battery consumption.
I had at my YAGER/Dink a blank cable within rear harness, close to my LH shock, very hard to find.
« Last Edit: March 08, 2023, 07:50:21 PM by Ruffus »
« Reply #2 on: March 07, 2023, 07:30:16 PM »
I, too had a Yager at one time as well as several other EFI Kymco models and I echo what Ruffus wrote. These will NOT spark if volts are below around 10 volts or less while cranking. Your starter relay must be fine since the battery was run down by trying to start. Quit with the starter button if it does not fire within one to three revolutions. Try once, RR-RR-RR then quit. Wait a bit, 1,2,3,4,5 then try again: RR-RR if it does not start then, STOP! Get a jump or take the bus.
These Kymco systems are marginal at best but are normally quite reliable if the battery and CONNECTIONS are near perfect. System grounds seem the weak point and very prone to corrosion. Connections should all be treated with silicone dielectric grease when brand new to prevent some of these problems. They all should be treated today after cleaning if not done initially.
You came to the right place for answers. Ruffus got you started. Do exactly like he says and you will solve this! Keep us posted as you go along. And definitely when it gets solved.
GermanYager200i
« Reply #3 on: March 08, 2023, 03:06:55 PM »
@Ruffus / @CROSSBOLT
Thanks a lot for your input.
I will try to get to it between business trips and update.
Again, much appreciate the help!
Best regards from snowy Germany
EDIT:
Can you specify where exactly I should look for corrosion and then apply grease?
« Last Edit: March 08, 2023, 03:12:02 PM by GermanYager200i »
« Reply #4 on: March 08, 2023, 07:31:44 PM »
For this corrosion stuff maybe see this link, it's a LIKE 200i but setup is the same. Cable is bolted to the backside of your scoots starter motor vicinity.
https://www.kymcoforum.com/index.php?topic=31637.0
(Pls see pic)
If you open your battery cover you will see a fuse box, check this connectors beneath.
Best approach would be to take your seat inclusive underseat tray out to see cable harness and all connectors.
https://www.kymcoforum.com/index.php?topic=31878.0
« Last Edit: March 08, 2023, 08:12:18 PM by Ruffus »
GermanYager200i
« Reply #5 on: March 09, 2023, 06:17:16 PM »
@Ruffus: thanks for the detailed explication.
To update on my case:
I did get to it yesterday already and checked the battery cables. Current was flowing fine. My Yager doesn't have the socket, so I looked at the lamp.
I then figured out that the issue is way simpler after all.. the light bulb was not switched off by closing mechanism of the seat. I tested it by taking a video with the phone in the helmet compartment. I then put some grease on it and closed it a few times with more force + some verifications with a screwdriver.
The light bulb now switches off and so far the scooter starts nice and smooth each try. I will let him stand over the weekend and update again, but I am pretty confident that this was the issue. Just beyond disappointed and surprised that both shops didn't figure this out.
« Reply #6 on: March 09, 2023, 06:36:31 PM »
The old "cell phone video in the sandwich locker" trick!
Well done you!
Hope that fixes it!
« Reply #7 on: March 09, 2023, 08:08:19 PM »
Good to read you got it! I was about 80% sure it will be that.
Had this issue, final cure for that was (because it will happen again) to remove this mini-switch.
Switch is located at/ within (part of) your seat lock. It's a square (8x8mm) standart push switch, can easily be removed when your undertray is off.
Sometimes shops don't have time or will to search on used scoots.
Keep us posted.
« Last Edit: March 09, 2023, 08:15:44 PM by Ruffus »
Louder North
« Reply #8 on: May 16, 2023, 07:33:59 PM »
When I'm working on my Kymco with the seat open, to save battery power, I will manually close the latch at the back with my finger or the blade of a screwdriver (you could test the light turning off this way as well).  To close the seat again, use the key as you would to unlatch the seat first, then close it.
2009 Kymco Frost (aka Yager 200i)
10,000 km
bought used in 2018
2007 Aprilia SR50 (Morini motor)
2013 Aprilia SR50 (Piaggio motor)
1986 BMW R80
GermanYager200i
« Reply #9 on: August 09, 2023, 05:00:12 PM »
Keep us posted.
Hey guys,
Sorry for the delayed reply. I was abroad for a while and upon return it did work well, but now the problem re-occured.
I did check for the switch, but I could not find it.
@Ruffus: Where should it be (see attached fotos)?
« Reply #10 on: August 09, 2023, 07:43:54 PM »
..look where this red arrow is, push in there with a screwdriver and pull the switch towards RH out..
Louder North
« Reply #11 on: July 16, 2024, 07:12:32 PM »
Hey guys,
I had a difficult time starting my Kymco Frost (Yager) when the battery was a bit low - if attempting to start it for > 30 seconds and it doesn't start, the spark plug will also be wet so even if you charge the battery for a few hours, it still may not start unless you dry out the spark plug first.
10,000 km
bought used in 2018
1986 BMW R80
