Author Topic: 2022 Kymco People S 150i kill switch bypass  (Read 2006 times)
smoral12
« on: March 20, 2023, 11:48:39 PM »
How do I bypass the scooter kill switch? Thanks.
Sergio
Re: 2022 Kymco People S 150i kill switch bypass
« Reply #1 on: March 21, 2023, 01:20:10 AM »
Do you mean make the switch so that it can't shut off the engine?
smoral12
« Reply #2 on: March 21, 2023, 09:40:39 PM »
Switch is defective. I want to bypass it until I can get a replacement switch. Thanks.
Sergio
« Reply #3 on: March 22, 2023, 08:02:01 PM »
@smoral12, welcome here.
Before you do below mentioned, please try to soak this switch with some WD40 or similar.
No success..?
If it's not a permanent fix do following:
-open your RH switch
-there are two cables which stop/kill your motor
-those are soldered into this kill switch
-extract and connect them
-isolate this connection
-test whether your scoot starts
-install your RH switch.
Try to get a good used one.
« Last Edit: March 22, 2023, 09:20:26 PM by Ruffus »
smoral12
« Reply #4 on: March 22, 2023, 09:32:00 PM »
Thank you.
