Poll
What should I check next to see what is wrong with my scoot
Carburation
1 (50%)
Spark plug
1 (50%)
Piston rings
0 (0%)
Connecting rod
0 (0%)
Bent crank
0 (0%)
Total Members Voted: 1
Voting closed: April 25, 2023, 02:52:45 PM
Author Topic: Hard Starting with Old and NEW Top Ends  (Read 2098 times)
tyguyc
« on: March 31, 2023, 08:48:02 PM »
Hello,
First time caller, long time listener.
I have a 2004. Got it a few years back non runner.
Had to disassemble the jug to find there was water that made it in there and pitted the walls pretty good.
Cleaned it out and slammed it back together and made it run.
But it was always really not fond of starting. It would seem as though there was a harder spot in the rotation. But it seemed like more of a backfire than actually caused by the rust.
Once it did start it ran pretty good. After 2 years of abuse like this the battery had been weakened enough to not really start this machine reliably.
When it was warm it started a little easier but still not really an easy feeling when you are XX.X miles from home.
So I ripped the top end apart late this winter to get it prepped for this spring. I had purchased  a 2008 head (the one with a decompression lobe?) and a slightly used cylinder earlier last year. And just purchased a piston and base gasket this year, dont judge my sloppy rebuild skills.
The piston ended up being a smart purchase bc mine was pretty scored on the bottom sides. reused the rings and headgasket.
Then yesterday I put it all together making sure that the T mark on the flywheel lined up with the 2 dots on the cam (and used the screwdriver method to make sure that the piston was at the top of the stroke)
torqued it all together, put the valve cover back on and threaded the spark plug in.
It rotates better now but still seams like there may still be a spot where its a little tighter than the other spot in the rotation.
And it still does not like to start easily.
It still backfires a little like the timing is too advanced. It did cough a few times when I tried to start it and choking it did seam to help a little. But not enough to get it to run for more than a second, if that.
Also this is with a new Carburetor but it never ran with the carb off it (just as a test).
So 3 questions.
What is wrong with my poor scoot? I would love to ride it but its so hard to start I hardly break it out.
What is the proper way to make sure that the ignition timing it actually proper?
AND
What is the the default setting the CDI Uses when its not getting the TPS Signal?
I'm Sorry and Thanks, in advanced.
Re: Hard Starting with Old and NEW Top Ends
« Reply #1 on: April 01, 2023, 05:23:51 PM »
there's not much more to the timing other than what you have done..line up the mark on the flywheel and have the 2 dots on the cam gear parallel with the head, making sure your piston is at the top of the stroke. I haven't read anything about valve adjustment? That can contribute to hard starting.
« Reply #2 on: April 01, 2023, 07:51:41 PM »
@tyguyc welcome here!
After all this read:
-100% sure the exactely same cylinder?
-piston rings reused and maybe not turned properly horizontally to avoid blowby (blue smoke)
-head gasket blowing (compression test?)
-once again check timing marks when at TDC
-sparkplug wet from fuel
-sparkplug out and check sparking
-check carb again
One more thing came in my mind:
 You said you replaced your carb.
 Your carb is fed by a vacuum fuelpump, where there are three hoses. (pls see pic)
One IN from fuel tank, one OUT to your carbs float chamber and one more, which is the vacuum TO/FROM carb, line. Maybe there is something wrong with tubes or this diaphragm is faulty.
Pls give a feedback for us to learn
« Last Edit: April 02, 2023, 06:42:29 PM by Ruffus »
tyguyc
« Reply #3 on: April 03, 2023, 06:54:44 PM »
Thanks Iahawk this is a bit of a moot point now that my girlfriend has now left me. But this thing rides like a couch so i will carry on.
You are correct in me not preforming a valve adjustment procedure, as they seemed to have the correct lash when I installed them.
What are the things that can contribute to a few degrees of rotation to be 'stickier' than the others?
read further.
tyguyc
« Reply #4 on: April 03, 2023, 07:11:13 PM »
-check carb again
Thank you Sir Ruffus. The fuel pump is out of the equation. I temporarily capped the vac ports and filled to bowl. (but it does work)
No but over %95.
There is some blue smoke, but I believe that is the new head being in worse shape than my old head. But I realize it could be both.
I did a DIY job to flatten the mating surfaces and the MLS Gasket was in decent shape. I didnt break out my compression tester but it is making good pressure.
Double checked and actually went one tooth advanced to try and get that intake valve to close sooner.
checked and yes.
checked good
-check carb again
I did plug in the old carb with the TPS Sensor and didn't make any actionable difference, but I also put 1-2 mL of gas down the intake and that didnt have any effect either.
What can cause these kinds of engines to have a hard spot in the rotation? The starter seems to struggle in one area of rotation and I wonder if thats my root cause.
« Reply #5 on: April 03, 2023, 09:22:31 PM »
"What can cause these kinds of engines to have a hard spot in the rotation? The starter seems to struggle in one area of rotation and I wonder if thats my root cause"
Is this "rough" spot even when the sparkplug is removed?
If yes, there could be a slightly bent piston rod, just a guess.
I would strip CVT (belt off) to get a clear pic where
the engine is "clutching", then try to start with CVT off, to find the culprit in that way.
THEN
starter motor out and revolve the motor by hand to see whether its really braking somewhere...
Are you trying to start with direct fuelling, without vac pump?
AND, do you have in your carbs idle-jet  this mini washer and o-ring?  (pls see pic)
« Last Edit: April 03, 2023, 09:49:30 PM by Ruffus »
« Reply #6 on: April 04, 2023, 01:05:52 PM »
as Ruffus suggested, have you pulled the spark plug and turned the motor over by hand? That should give you a good feel and if there's truly a spot in the rotation that is harder to move through.
I should re read your previous posts..but are you sure your starter motor is good?
tyguyc
« Reply #7 on: April 11, 2023, 02:48:02 PM »
Yes I took out the starter motor and bench tested it. Appears good from everything i can see.
tyguyc
« Reply #8 on: April 11, 2023, 02:50:24 PM »
THEN
CVT Came off and no real difference in hard spot.
Starter then came off, again no real difference in the hard spot.
I dont think it has anything to do with fueling, at all.
« Reply #9 on: April 11, 2023, 08:24:03 PM »
Ok, IMO not a fuel thing either
- CVT off
- startermotor still out
- sparkplug out
- big 17mm nut on its place
- turn the crankshaft by socket and ratchet
(YES clockwise, backwards)
- do you see a measurable wobble on your crankshaft?
- is this oilseal there leaking?
- where does it crunch?
- listen carefully into cylinder during turning
- where is a scratching/blocking, at which point?
- is it repeatable?
You wrote, scoots innerts were pretty corroded, there might be a mainbearing suffer too.
Listen there whats doing.
- listen into this startermotor hole too, there is your starter freewheel, maybe there?
So, when all this does not reveal anything...
- spark there (new sparkplug)
- fuel there (plug wet)
- air there (airfilter off)
I might suspect your timing chain a few teeth off.
« Last Edit: April 11, 2023, 09:01:33 PM by Ruffus »
tyguyc
« Reply #10 on: April 27, 2023, 04:57:49 PM »
To those of you that guess Bent Crank. Give yourself a pat on the back.
These split pin cranks are pretty tough, but they do have their weakness.
(btw if you need to align one, you have to hit it HARD. and likely with it on a hard surface as well)
Put it all back together now and it spins as it should.
I did not seal the case properly so it leaks oil now  :o. oh well.
Thanks for all that commented on potential problem child's.
« Reply #11 on: April 27, 2023, 09:57:08 PM »
Thank you for your feedback, I'm glad you found out and it works, concrats👍👍
« Reply #12 on: April 28, 2023, 01:00:47 PM »
Always good to hear the outcome on knotty problems like this so, as Ruffus says, thanks for the feedback!
