Author Topic: gear box 90w-tool  (Read 1546 times)
Cloud
gear box 90w-tool
« on: December 05, 2010, 12:21:44 AM »
2004 People 50
1. What tool do you use to replace 90w oil in gearbox?
2. Does it have measurements on it?
3. Where do you buy it?
This is the amount I will put into the gear box.
.18l=180ml=6.09 Fluid Ounces
« Last Edit: December 05, 2010, 03:01:35 AM by Cloud »
juice
Re: gear box 90w-tool
« Reply #1 on: December 05, 2010, 12:49:44 AM »
Hopkins 10111/6 MFG 2-Cycle Oil-Mixing Tool
It is a 2 oz syringe that will shoot the oil into the small hole , I bought mine at walmart . Good luck .
« Reply #2 on: December 23, 2010, 09:33:35 PM »
Just did my first oil change on my Super 8.  The syringe for filling the gearbox worked great.  Got mine a Wal Mart.
sc00ter
« Reply #3 on: December 30, 2010, 05:29:53 AM »
Also known as the Mix-Mizer. Got mine from K-Mart. Makes gear box changes really easy. Has cc's on it. Not sure about the People 50 but most smaller scoots use around 110cc's. Also most use either gear oil (summer) or 10-30 (winter). I had gear oil in my old Buddy 125 and one supper cold night the scoot felt like the rear brake was on from the gear oil getting to cold. Switched to 10-30 during winter and its much better. Check the owners manual to be sure.
