Author Topic: Just Bought a tatty Kymo  (Read 2044 times)
Kymco Symco
« on: April 04, 2023, 05:57:40 PM »
Hi
first post here. i've bought a cheap tatty 2012 downtown 300 i. it needs tidying up in places and various bits fixing/replacing
as i'm learning my way around the scooter.....under the seat. i wonder if anyone can tell me whats missing from here ?
first pic is rear of bike on l/h side
2nd is near side stand cut out block
thanks
Re: Just Bought a tatty Kymo
« Reply #1 on: April 04, 2023, 06:10:52 PM »
@xwelder welcome here!
Pls see link and diagram/pics
https://www.manualslib.com/products/Kymco-Downtown-300i-Abs-8827007.html
There should be a wiring diagram. Follow colors there and here we go.
« Last Edit: April 04, 2023, 08:46:07 PM by Ruffus »
Kymco Symco
« Reply #2 on: April 04, 2023, 06:47:24 PM »
Pls see link
thanks......still looking thru everything for the loom
« Reply #3 on: April 04, 2023, 07:09:33 PM »
Bottom picture is side stand switch connectors. Bet the side stand switch is missing. The plug with green and yellow plugs into the socket with two greens if those are near the side stand. Fix the splices first then plug together.
Needless to say this bike won't start unless another jury rig has been made elsewhere....
NorWeWa
« Reply #4 on: April 04, 2023, 08:18:19 PM »
First pic looks like the plug for the diagnosis device. Hangs under the small cover at the end of the underseat tray.
Art
mousejunks
« Reply #5 on: April 05, 2023, 12:06:44 AM »
First photo is the 3 pin diagnostic connector, it hangs from a clip on the rear of the seat tub.
Second photo is the side stand switch bypass. You can plug them into each other so the bike can run with the side stand down. Here's what it should look like when working.
https://www.kymcoforum.com/index.php?action=dlattach;topic=26124.0;attach=16072;image
« Last Edit: April 05, 2023, 12:08:19 AM by mousejunks »
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
Kymco Symco
« Reply #6 on: April 05, 2023, 05:50:03 PM »
thanks for all the help with this question . much appreciated
i'm using the quote feature here as theres no option to post a reply only this message " An Error Has Occurred!
« Reply #7 on: April 05, 2023, 07:35:12 PM »
You must not be holding your mouth right if this quote and message works!
« Reply #8 on: April 05, 2023, 08:10:46 PM »
you can just do a reply without quote if you go up top and hit the 'reply' button
Kymco Symco
« Reply #9 on: April 06, 2023, 06:38:18 AM »
thanks.....didn't think to check the top of the page . didn't see reply then that error message and 2 + 2 = 6 :)
Kymco Symco
« Reply #10 on: April 07, 2023, 06:58:03 PM »
Hi
currently refurbing the brake calipers....does anyone know the part numbers for the front brake caliper seals ? the dust & main seal
found the rear on line but can't find the front
thanks
« Reply #11 on: April 08, 2023, 08:49:31 PM »
Should be those pieces... pls see pics
« Last Edit: April 08, 2023, 09:03:25 PM by Ruffus »
Kymco Symco
« Reply #12 on: April 09, 2023, 07:09:02 AM »
thanks....have you a link to where you found this ? or the full part numbers for the seals
« Reply #13 on: April 09, 2023, 11:19:52 AM »
Sitting here in EU/Italy I just send my dealer those numbers with vehicle ID and pick it up couple of days later.
Kymco Symco
« Reply #14 on: April 09, 2023, 02:52:41 PM »
i did some searches and the partial part numbers bring up nothing sadly
