Author Topic: DTX360- It’s that time of year again….  (Read 308 times)
« on: April 07, 2023, 10:18:03 AM »
Do I ride 6m on the wrong time or try to fathom how I change the clock on my new DTX360?  Go to Google has failed me so it’s out with the User Manual 😳
Re: DTX360- It’s that time of year again….
« Reply #1 on: April 07, 2023, 10:55:38 AM »
Easy enough it seems, on RH bar.
“In Odo mode press & hold the down button to select the digits
Press the O button to change the digits
Press the down button to select hours or minutes, they will flash when selected”
I’ll come back and edit if that’s not quite right.
Edit:  Clock adjustment:
Ignition on then in ODO mode, press and hold the DOWN button for a few seconds to adjust the digits. Then:
•   Press the DOWN button to select hour or minute.  The digits will flash as they are selected.
•   Press the O button to change the digits.
•   After change wait c10 seconds for it to set.
« Last Edit: November 07, 2024, 03:30:55 PM by Neil955i »
