Author Topic: 2009 People 250 keeps shutting off  (Read 1310 times)
Klaatu4u
« on: April 07, 2023, 02:30:26 PM »
My 2009 People 250 with 8000 miles on it has always run perfectly.  Today....I was cruising at about 45 mph, when the engine just shut down.  I could start back up, but, if I didn't keep a little throttle on, it just kept shutting off.  So...slowing down to a stop sign or red light would a shut down as well.  It restarts, but keeps shutting down?  What is the problem??  Thank you!@
Re: 2009 People 250 keeps shutting off
« Reply #1 on: April 08, 2023, 08:41:42 PM »
@Klaatu4u, welcome here!
Your scoots symptoms could have several reasons:
was your scoot parked for awhile?
- fuel contaminated with dirt or water
- fuel pump or lines faulty
- fuel tank perpiration not working
- ignition system, coil-sparkplug-cap failing
- idle too low
- CVT,  rollers, belt, clutch not in shape
Try to approach systematically your rides dark spots.😉
Qs? Shoot away!
