Author Topic: [Solved] Can't reach top speed  (Read 3384 times)
NorWeWa
Re: Can't reach top speed
« Reply #15 on: June 03, 2023, 03:28:57 PM »
Sounds like a CVT issue. Rollers to light, or belt wore out or wrong belt.
« Reply #16 on: June 03, 2023, 08:26:02 PM »
Speedometer is in KPH, not MPH? Yes?
darkshvein
« Reply #17 on: June 13, 2023, 08:07:17 AM »
Yes, kilometers per hour.
darkshvein
« Reply #18 on: June 13, 2023, 08:09:20 AM »
I already changed the pads and the belt. Old and new belt - same issue.
I will check rollers, thanks.
darkshvein
« Reply #19 on: October 16, 2023, 09:42:54 PM »
Well. Thanks all. Variator was repaired in service.
I guess, that this detail was a reason for slow speed:
degraded stopper ramp plate 22133-lba2-e00
Re: [Solved] Can't reach top speed
« Reply #20 on: October 17, 2023, 08:41:37 AM »
Do you have more details or pics from that. Would be interesting. Txs.
mousejunks
« Reply #21 on: October 17, 2023, 11:46:13 AM »
I also had a defective ramp plate which caused sudden acceleration issues.
'09 Kymco Espresso 150i
'17 Kymco Downtown 350i ABS
darkshvein
« Reply #22 on: November 14, 2023, 09:22:27 PM »
As I remember, 22133-lba2-e00 this detail (screenshot)
« Reply #23 on: November 14, 2023, 09:45:23 PM »
Ah txs, got it: inner, towards motor washer on crankshaft.
« Last Edit: November 14, 2023, 10:20:36 PM by Ruffus »
« Reply #24 on: November 14, 2023, 10:42:28 PM »
Jumping to conclude this was missing?
« Reply #25 on: November 15, 2023, 08:17:10 PM »
Makes sense, opens front pulleys further than planned, belt lowers, less power on clutch.
This bigger motors are really sensitive on their three different shaped washers.
darkshvein
« Reply #26 on: December 07, 2023, 03:03:51 PM »
Good day, guys.
In addition,
I replaced the expensive Mitsuboshi belt with an original one, already relatively cheap from eBay. the length is the same, visually 3-4 mm wider. The scooter is finally back to 150/7500 speed
I SO f***ing happy.
this is:
https://www.ebay.com/itm/195327459209
warning, my kymco 500i are 2010 year. (if this important)
« Last Edit: December 09, 2023, 12:59:38 PM by darkshvein »
« Reply #27 on: December 07, 2023, 07:54:21 PM »
OEM KYMCO belts are the only way to go......but owners will spend a lot of effort trying to match the size.
Close, unlike grenades, is not close enough.
