Did you miss your
activation email
Scooters - 50cc
zx50
Picked up a '02 ZX50
Pages:
Topic: Picked up a '02 ZX50 (Read 3957 times)
buickid
Newbie
Re: Picked up a '02 ZX50
Reply #15 on:
February 17, 2011, 05:07:30 PM »
Well the problem is, its still stuck on there, and substantial force will be required to remove it, it seems... I tried looking on eBay, but I couldn't find anything with "zx50 reed" or "zx 50 reed". What are you searching for?
Shaka
Reply #16 on:
February 25, 2011, 06:23:45 AM »
I've got a set of oem reeds I could make you a deal on. Otherwise, PM me and I can help point you in the direction of some aftermarket stuff. That stuff really won't work well on a stock set-up though. If anything you can change the oem metal reeds for some carbon ones, but still use the same reed block.
thebatman
The Bat lives on... like the fkn Energizer Bunny
Reply #17 on:
February 25, 2011, 04:42:48 PM »
true that unless you have a heavy modded stock......
If you get the oem, be sure to port the cage itself out... good for 1mph...
I can post a pic showing you how i had done mine if needed
"THE BAT"MAN...
Says:
buickid
Newbie
Reply #18 on:
February 25, 2011, 06:22:16 PM »
I got the cage off without further damage, I'm gonna try patch it up with gasket sealer once my gaskets come in
Back
