Author Topic: Opening The Coolant Access Panel  (Read 1460 times)
Phil65
« on: April 23, 2023, 09:01:39 PM »
Hi. I feel like an idiot as I can’t open/remove the radiator filler cap access panel above the level window on my People 250 S. I’ve removed the screw but feel like I’m going to break the hatch or severely scratch the metallic paint trying to lever it open with a screw driver etc
Re: Opening The Coolant Access Panel
« Reply #1 on: April 24, 2023, 02:39:07 PM »
@Phil65, welcome here.
Don't worry, spray some WD around this little hatch to soften sticky parts in between. Let it soak awhile then pry with something like a thin spatula there. Has a latch on one side.
Maybe give us a feedback.
« Reply #2 on: April 24, 2023, 03:18:22 PM »
Plastic pry tools used for car interior panels (c$5 a set) would be ideal?
Phil65
« Reply #3 on: April 24, 2023, 06:22:53 PM »
Thanks guys. I realised today that I could push  it from the inside by putting my had through the fairing past the front forks . Eventually opened after a few attempts
mrbios
  • 2005 Kymco Grandvista 250cc
    • My YouTube Channel
« Reply #4 on: May 13, 2023, 04:24:36 AM »
Good work and thanks for the update.  Consider applying a little grease or oil to plastic parts to help the snap back into place.
PaulC
