Author Topic: Keihin Main Jets  (Read 10322 times)
Rianna
Re: Keihin Main Jets
« Reply #30 on: December 10, 2010, 12:54:03 AM »
I found a sticker on my scoot with the 'odd' numbers on it,  oswaldters. The sticker wasn't on the carb, though, it had been moved. So I guess I won't know for certain until I take a look at it.
oswaldters
« Reply #31 on: December 10, 2010, 12:57:02 AM »
Yeah, with my luck I've go the odd carb as well.
I hope to find out in the next couple of weeks when I get around to checking it out.
Rianna
« Reply #32 on: December 10, 2010, 01:03:17 AM »
You'll probably find out before me, oswaldters. I'm not doing much of anything in this 20 degree weather.
oswaldters
« Reply #33 on: December 10, 2010, 01:06:00 AM »
Well, if it stays this cold then I'll have to think about changing that pilot jet too.
Rianna
« Reply #34 on: December 10, 2010, 01:08:04 AM »
Well, if you do that, what would you change it to?
oswaldters
« Reply #35 on: December 10, 2010, 01:11:16 AM »
That's a good question - I'd have to check the size of it now - I think something like a #35 but I'm totally guessing.
Rianna
« Reply #36 on: December 10, 2010, 01:12:25 AM »
Yeah, the original slow jet is supposed to be a #35...
oswaldters
« Reply #37 on: December 10, 2010, 01:14:13 AM »
So I might go up a size on that.
But the main jet is the first thing I have to deal with.
Rianna
« Reply #38 on: December 10, 2010, 01:16:44 AM »
I see. I don't know about where  you're at but it's "supposed" to be in the 40's here tomorrow. I'm really hoping it does.
oswaldters
« Reply #39 on: December 10, 2010, 01:19:41 AM »
I think high 30s maybe.
A veritable heatwave, I may have to wear my shorts to ride in.
« Last Edit: December 10, 2010, 02:50:28 AM by oswaldters »
Rianna
« Reply #40 on: December 10, 2010, 01:22:30 AM »
:D Shorts!! Better U than me!! :D
Chachivoodoo
« Reply #41 on: December 19, 2010, 10:16:24 PM »
I received the Jets, they were correct, and fit.
I installed a 38 Pilot Jet and a 90 Main Jet.
I adjusted the mixture with the air screw after it was warmed up.
Set the air screw at about 1-1/4 out.
Starts much easier now.
There was a little bit of a stumble in the bike in the midrange until it got warmed up.
Runs fine, looks like i'm all set until the summer comes back, then I'll probably drop the main jet to an 85.
We will see.
2005 PEOPLE 50CC 2 STROKE
Leo Vince Pipe- DE-RESTRICTED
BOSS DRIVE: DE-RESTRICTED
CDI: DE-RESTRICTED
90 Main Jet
38 Pilot Jet
1/4" Hole in Airbox to let it breathe...
oswaldters
« Reply #42 on: December 20, 2010, 12:21:07 AM »
Glad to hear everything worked out.
Thanks for keeping us updated - this info is helpful in my quest to get my carb working better.
« Last Edit: December 20, 2010, 03:08:07 AM by oswaldters »
Rianna
« Reply #43 on: December 20, 2010, 02:32:15 AM »
That's great, Chachivoodoo. Now you're ready to roll!
I'm glad they fit for ya!
bniesen
« Reply #44 on: March 22, 2011, 03:37:59 PM »
Isn't #85 the stock size, at least that what it says in the manual. Has anyone tried restricting the air flow instead of changing out the jets?? In colder weather air is more dense so if the mixture is too lean then couldn't you just restrict the air flow?
Maybe I'm just stupid.
