Author Topic: engine noise  (Read 1906 times)
Kymco Symco
engine noise
« on: April 26, 2023, 03:32:37 PM »
bought as a non runner.....yep i know....
anyway.....starts up.....little rev and you get a sound where i thought either a gear was rattling round on a shaft or a flywheel coming loose sound.....
ripped off the engine cover on r/h and all looks good.....
any ideas ?
NorWeWa
Re: engine noise
« Reply #1 on: April 26, 2023, 04:07:06 PM »
Not sure what you mean, "engine cover on the r/h"
Kymco Symco
Re: engine noise
« Reply #2 on: April 26, 2023, 04:09:51 PM »
i thought the sound might be coming from the engine...so i took the cover off the engine which is on the right hand side of the engine....the waterpump side...
NorWeWa
Re: engine noise
« Reply #3 on: April 26, 2023, 04:19:46 PM »
Look into the CVT. Remove the cover off the left side rear .
Kymco Symco
Re: engine noise
« Reply #4 on: April 26, 2023, 04:25:47 PM »
i removed the cover....all was tight.....so removed the drive gear on left........one drive from engine.....
started engine...revved up....noise still there.....it kind of sounds like the driver gear that the starter motor turns.....only thing i can think of....
NorWeWa
Re: engine noise
« Reply #5 on: April 26, 2023, 04:26:42 PM »
You can get a manual from off this list.  https://kymco.at/kymco_store_view/dowloads/kymco.html
Kymco Symco
Re: engine noise
« Reply #6 on: April 26, 2023, 04:30:53 PM »
thanks...will take a look
NorWeWa
Re: engine noise
« Reply #7 on: April 26, 2023, 04:39:55 PM »
Removing the seat and the under seat storage bin will get you a good view of the motor and starter.
Kymco Symco
Re: engine noise
« Reply #8 on: April 26, 2023, 04:45:06 PM »
already did that......all apart to get better access.....
Kymco Symco
Re: engine noise
« Reply #9 on: April 29, 2023, 08:21:08 AM »
Bit more more earlier this morning
advice on this please ?
best guess....feels like a crankshaft bearing has failed ?
https://mega.nz/file/oU1gFAQR#VK4ms76-DhTVwA6fccDNQBoxu1Uu7C9YIGyuWa600L4
« Last Edit: April 29, 2023, 12:37:09 PM by xwelder »
NorWeWa
Re: engine noise
« Reply #10 on: April 29, 2023, 03:23:59 PM »
Can you feel up and down play when you apply force to the Variator, which is on the end of the crankshaft. ?
Kymco Symco
Re: engine noise
« Reply #11 on: April 29, 2023, 03:26:03 PM »
the crankshaft seems to have end float...it can move left/right to get that noise and on r/h side it also i think can move up /down
NorWeWa
Re: engine noise
« Reply #12 on: April 29, 2023, 03:44:48 PM »
There should be no movement. side to side or in and out. You may have identified your problem.
Kymco Symco
Re: engine noise
« Reply #13 on: April 29, 2023, 05:30:02 PM »
yes....and it will involve dropping the engine out & stripping it apart
NorWeWa
Re: engine noise
« Reply #14 on: April 29, 2023, 06:03:46 PM »
A lot of work for sure, but you learn a lot and labor is the biggest cost in rebuilding a scooter.
