Author Topic: engine noise  (Read 1907 times)
Re: engine noise
« Reply #15 on: April 30, 2023, 01:40:29 PM »
these motors are very easy to pull apart and rebuild. I see your 300 is built with the same architecture as my smaller 163cc. I found it easiest to remove engine still connected to rear wheel and roll the whole assembly out. Take detailed notes on what order you disassemble everything, take pictures and bag and label all the parts that go together.
The gaskets and seals are relatively inexpensive. Might be a good time to replace cam chain guides, too.
The absolute biggest pain in the whole process was scraping the old gasket material from the aluminum cases. There's no secret sauce, just time and sharp razor blades.
Reassembly is easy but I'd recommend having a shop manual for torque specs, etc.
Re: engine noise
« Reply #17 on: July 05, 2023, 04:26:56 PM »
took a few weeks to suss it out....but i finally got it running
That's nice but WHAT did you do that got it to go?
Re: engine noise
« Reply #18 on: July 07, 2023, 01:46:30 PM »
Oh, so sorry to hear this! Well, now you have some nice spare parts!
Kymco Symco
Re: engine noise
« Reply #19 on: July 30, 2023, 10:16:06 AM »
from time to time yes .
thanks
