Author Topic: A 450i uxv 4x4 no start problem not on the forum....yet  (Read 1352 times)
JNH70
« on: May 13, 2023, 12:30:51 AM »
I bought my 450i uxv 4x4 new in 2021. It has been running perfectly. All maintenance done as required. Love the thing. Recently though I will turn it on.... dash lights come on and buzzer sounds but no crank, no noise. no anything at all as if it had a bad ignition switch. I have realized if I put it in neutral it starts right up or if I rock it back and forth it starts right up. Yes, I am always pressing the brake pedal when starting.
Is it a transmission position sensor issue?
I read the other posts about starting problems, but my starting problem is not similar. I have power to the on position, but no crank, no nothing unless it is in neutral or I rock it back and forth. Battery is good, connections are good, wires are good.
Thoughts?
Thank you in advance!
JH
mstparker
Re: A 450i uxv 4x4 no start problem not on the forum....yet
« Reply #1 on: May 13, 2023, 01:04:11 AM »
Sounds like something is not telling it that the brake is being pressed.
« Reply #2 on: May 13, 2023, 03:32:50 AM »
Bingo! Bet you are right!
JNH70
« Reply #3 on: May 13, 2023, 12:17:43 PM »
Thank you for your thoughts! I will investigate the brake observations.
« Reply #4 on: May 13, 2023, 01:19:45 PM »
Off-road Kymcos have a one year warranty?, not 2 like the 2 wheel models?
« Reply #5 on: May 13, 2023, 02:34:43 PM »
have you tried starting in neutral?   brake do not need to be depressed in neutral, if it starts, you have narrowed the problrm to the brake switch
JNH70
« Reply #6 on: May 13, 2023, 10:47:34 PM »
Yes, it will start in neutral or if I rock it back and forth it will start in park. Battery is strong all wiring and connections are good. I have played with the brake adjustment and it does not really effect anything. I am investigating if there is another brake switch and anything related to the transmission position relative to starting.
I got a repair manual but it is no help with this particular problem. I am using it to go through every connection, sensor and switch related to the brakes, transmission and starting. It is a very odd problem.
JNH70
Re: A 450i uxv 4x4 no start problem not on the forum....yet / RESOLVED
« Reply #7 on: May 14, 2023, 07:00:02 PM »
Well after extensive checking of everything I could think of it seems it is a brake pedal or more precisely a brake adjustment issue as Randyo had noted and mstparker reiterated.
Today I adjusted the pedal multiple times in different positions and it seems, at least on my 450i, that I have a sweet spot in the pedal adjustment when if it is not in that sweet spot it produces the power on - no start. I had adjusted it before but I guess I did not get it in the sweet spot so it was consistent.
Anyway....thank you all for you observations and for now this is resolved.
« Reply #8 on: May 14, 2023, 11:08:33 PM »
Well after extensive checking of everything I could think of it seems it is a brake pedal or more precisely a brake adjustmehnt issue as Randyo had noted and mstparker reiterated.
Find the switch and adjust if mechanically activated or replace if hydraulic pressure activated.
« Reply #9 on: May 15, 2023, 12:39:07 AM »
I know that mine is due for adjustment, I never use park, I always put it in neutral and use the parking brake, but if it stalls for some reason while driving, I just depress the brake in what gear I'm in, I've noticed that I have to use a heavier foot as of late.
