Author Topic: Location of "Light Controller"  (Read 1826 times)
rocky1
« on: May 13, 2023, 10:12:16 PM »
My headlights do not work on my 2007 People S200.  I confirmed the bulbs work by connecting them directly to 12V.  After a research, I believe I have the known "light controller" problem and would like to "bypass" it as recommended by others.  However, I don't know where this "light controller" is.  Where is the location of the "light controller" on the 2007 People S200?  Thanks in advance.
Re: Location of "Light Controller"
« Reply #1 on: May 14, 2023, 01:52:14 PM »
welcome to the forum. The lighting control module is located behind the front panel, under the headlight. It's the thing circled in yellow in the picture. To remove the front panel you remove 6 screws that are facing the rider (3 to the right and 3 to the left of the glovebox area), 2 more behind the front tire and the little bolt that is hiding behind the plug at the lower front of the front panel. You remove the plug by slipping your finger up and behind it and popping it out, forward.
How many miles on your scoot? Color? How long have you owned it? We love pictures, here.
rocky1
« Reply #2 on: May 14, 2023, 08:31:22 PM »
Big thanks!  Now I just have to find time to troubleshoot again.  I thought it was near the headlight, but looks like I needed to go further down.  I'll admit that I gave up after I couldn't remove those 6 screws facing the rider as they just kept on spinning.  Frustration just kicked in, so I gave up. Now I need to figure out how to remove those screws that just keep spinning.
Anyways, here's a pic of my silver 2007 which I got in December (about 6 months ago).  It only has about 6800 miles and I only drive every couple of weekends.
« Last Edit: May 15, 2023, 09:33:48 AM by Ruffus »
« Reply #4 on: May 15, 2023, 12:36:05 PM »
thanks for the links, Ruffus. Rocky - if your screws only spin and don't back out..when you try to tighten them do they also just spin? If they are truly stripped, could you grab them with needle nose pliers to try to pull out?
« Reply #5 on: May 15, 2023, 01:30:25 PM »
Welcome, think klaviator did some brainwork there...
rocky1
« Reply #6 on: May 18, 2023, 08:21:46 PM »
@Iahawk and @Ruffus
Big thanks for all your help.  I eventually removed the screws by using a flathead to pull the screw head towards me while unscrewing.  I don't think I would have been able to find the two screws behind the front wheel, so I really appreciate mentioning the screws and location.  It was actually easier to remove the front panel versus the top panel.
With the help of the picture, I was able to identify what I need to unplug.  I then jumped blue to blue and white to white wires, then covered them up in electrical tape. I now have headlights again!  Woohoo!
Again, big thanks,  This is a really helpful forum.
« Reply #7 on: May 18, 2023, 08:29:08 PM »
Good to see YOU made it work.👍👍👍
Credits to evertdekker who contributed🥂.
« Reply #8 on: May 19, 2023, 12:36:15 PM »
glad it worked out! Now don't be a stranger..come on back and visit more often!
