Author Topic: Replaced Brake Pads, Lost All Brake Fluid  (Read 1302 times)
monkeybongos
  • Tampa, Fl
« on: May 16, 2023, 02:07:30 PM »
What's the trick to replacing brake pads (rear in this case) without all the brake fluid dripping out?
I removed the two screws holding the caliper together, could that be the problem?
2016 Wolf V-50 (sold)
NorWeWa
Re: Replaced Brake Pads, Lost All Brake Fluid
« Reply #1 on: May 16, 2023, 02:43:46 PM »
look this over.
« Reply #2 on: May 16, 2023, 05:17:34 PM »
@MB, no IMHO this is not the prob. Even if you remove all bolts on this calipers there will no brake fluid leakin' out.
I'm inclined to think one of your piston seals is either pushed out or demaged. Please check them and replace if neccessary.
Also check your brake line and bleeder valve for leaks.
  • Central Iowa
« Reply #3 on: May 16, 2023, 07:52:23 PM »
When I remove the calipers on my bike I make absolutely certain to put something between the pads to ensure the pistons don't push out far enough to leak out the fluid. When replacing pads I make certain to never touch the brake levers or parking brake. Both must be off. Usually the only bolt that really needs to be removed on many calipers is the pad pin or pins. But my Burgman needed the caliper to be removed from the disk to change the pads. Again, being very careful not to pull the brake levers or parking brake and even push the pistons back into the calipers if needed to insert the pads.
« Reply #4 on: May 16, 2023, 10:52:23 PM »
Yeah, MB, you have some bigger problem with your caliper. On slide calipers the only way to leak fluid is to crack open the bleeder or the banjo bolt..or have leaks around the pistons. As Ruffus suggested, likely piston seals.
monkeybongos
  • Tampa, Fl
« Reply #5 on: May 17, 2023, 12:19:59 PM »
Appreciate the replies, everyone.
Think Ruffus and Hawk are correct about the seals, as there is still leaking of brake fluid w the caliper reassembled and back in place.
At 27,000 miles, guess it shouldn't be a surprise the seals need replacing, but why there was no leaking before replacing the pads?
Not sure which rebuild kit from All Balls will fit--sent them an email asking.  May have to get a whole new caliper if they don't know
which rebuild kit would work.
Really like the Cali Classic, only downside is Lance is not widely recognized, so many part mfgrs don't list Lance scooters on their parts list.
« Last Edit: May 17, 2023, 12:53:16 PM by monkeybongos »
« Reply #6 on: May 17, 2023, 12:51:43 PM »
@MB, it's leaking anyway.
Take these pistons out and measure.
There are slightly differrent shapes available but this doesn't matter. Diameter is important.
Why is it leaking now:
- by pushing the piston and the gasket forward you loosened most probably some crusts in your caliper cylinders, destroyed the gaskets, which now caused it leaking.
Means: close observation and cleaning of this cylinders is recommended. If there are corrosion rings which cannot be removed by hand and @SCOTCHBRITE or similar, you will face leaking again.
Solution: honing plus new pistons and gaskets. Actually very easy, because this calipers are made from pretty soft alu, but needs some experience.
« Last Edit: May 17, 2023, 07:25:37 PM by Ruffus »
NorWeWa
« Reply #7 on: May 17, 2023, 05:05:51 PM »
Leaking brake fluid is a serious concern. You could lose the braking when you need it most.
Art
« Reply #8 on: May 17, 2023, 05:33:02 PM »
« Last Edit: May 17, 2023, 05:34:36 PM by Ruffus »
monkeybongos
  • Tampa, Fl
« Reply #9 on: May 17, 2023, 10:28:56 PM »
Ruffus, doctor of diagnosis.  Surprised you know about Scooter Dynasty.  They are my go to for Lance parts,
but don't carry replacement pistons as far as I know.  Not sure where to go for that (auto parts store?).
New caliper will take care of pistons and gaskets/seals--as well as brake pads, which I already bought--so most likely
will go that route.  Will take current caliper apart tomorrow to examine seals and pistons, see whether they can be rehabbed.
You make a good point, Art.  Front brake works fine, plus w my riding style and the engine braking this scoot has, I'm not
too concerned.  But the leaking needs to be addressed for sure.
« Reply #10 on: May 18, 2023, 08:19:15 PM »
@MB, if you are handy, then:
Rubber gloves and eye protection needed!
-take your caliper off hose and apart
-take detailed pics
-wash all parts with rubbing alcohol
-take a magnifier and check all parts for possible demages
-maybe your piston gaskets are still without holes
-IF YES (without gushes) put them short (10 min) in fuel they will swell a little bit
- out again and rinse with lots of alcohol, put aside
Caliper and cylinders:
-as I said, try to remove corrosion rings within cylinders with such a kitchen sponge and alcohol
-if you cannot feel any demage anymore, rinse and aside
-pistons are usually crome plated, if you see or feel lots of blisters or pittings, forget them
-if only some small blisters or pits, this piston might be able to be saved
-kitchensponge, alcohol again
Dryblow them.
If all your parts are refurbished and in halfway shape, reassamble with brake fluid or better with brake paste.
This is an emergency or oldtimer way to safe what is not longer available anymore.
« Last Edit: May 18, 2023, 08:23:19 PM by Ruffus »
stuo
« Reply #11 on: May 18, 2023, 08:42:07 PM »
I replaced the rear caliper on my Grandvista 250 and it cost $100 from Kymco via Leeson's, which seems a bargain to me compared to trying to repair it. I tried once to rebuild a caliper and it leaked anyway. I hope you have better luck than I did.
2009 GV 250
monkeybongos
  • Tampa, Fl
« Reply #12 on: May 22, 2023, 02:46:33 PM »
Is this enough pitting to cause leakage?
And is this a consequence of not changing the brake fluid for 4 years?
« Reply #13 on: May 22, 2023, 09:30:01 PM »
MB, IMHO no,
this pistons can be used again. Polish them a shiny as possible, check your gaskets for leaks (better new one), take brakefluid to assamble and you will be good to go.
New (thicker) brake pads make the gaskets sit at a different spot on your pistons and should hold tight.
And YES, water in your brakefluid causes this corrosion and pitting.
« Last Edit: May 22, 2023, 09:34:42 PM by Ruffus »
monkeybongos
  • Tampa, Fl
« Reply #14 on: May 26, 2023, 11:41:53 PM »
After brake fluid leaked while installing the new pads,
I filled the master cylinder w a bottle opened months ago to see if the caliper continued leaking.
I figured why use new fluid until I knew the leak stopped.  I know, it's not expensive, but I never thought it
would cause problems when used only to test for a leak.
I took the caliper off to check the pistons, and find the coating on the new brake pads is peeling off.
Would this be caused by old brake fluid?  In just a day?  Can these pads still be used if I scrub off all the black coating?
If there is a way to screw up, I'll find it.  Should change my name to Mechanic from Hell.
Pics show the front and back of the pads.  Single pad on top is the old on, two beneath it are the new ones.
Old pad = no peeling after 28,000 miles.  New pads = peeling after a few hours in 6 month old brake fluid.
« Last Edit: May 26, 2023, 11:46:47 PM by monkeybongos »
