Author Topic: Horn  (Read 339 times)
Lancedjohnson
Horn
« on: May 20, 2023, 03:34:55 PM »
Anybody have a horn diagram? Mines not working. 700 atv.
stuo
Re: Horn
« Reply #1 on: May 20, 2023, 06:02:10 PM »
I'd pull the wire connections off the horn, clip a volt meter to the two wires (one side of the horn may be grounded in which case you clip the + probe to the horn wire the other to ground) press the horn and see if it's getting 12 volts. If it is, the horn is bad, if no voltage the problem is either the horn switch, the horn relay if there is one (see the wiring diagram), a loose wire or bad ground...or less likely, a fuse. My vote is a bad horn. Please report the solution.
2009 GV 250
