Author Topic: speedo  (Read 1357 times)
Kymco Symco
speedo
« on: May 27, 2023, 04:17:00 PM »
what drives the speedo on the front wheel ?
Kymco Symco
Re: speedo
« Reply #1 on: May 27, 2023, 06:27:57 PM »
and another.....i can see i'm not to first to work on my DT.....and unsure if the ht coil is plugged in correctly
the black wire & the green /striped one.....which wire is on top ?
thanks
Re: speedo
« Reply #2 on: May 27, 2023, 09:00:37 PM »
That "tone ring" circle thingy with the rectangular slots all the way around and the electric/electronic sensor that hovers over the slots.
Black wire goes on the end with just one connection. Green w/stripe on end with two connections (spark plug wire/fat, black & skinny green). According to the wiring diagram. A smart a_ _ answer would be "back on where you pulled it off!"
I even draw pictures when I remove the spark plug to make sure it goes back inna right place!
« Last Edit: May 27, 2023, 09:11:18 PM by CROSSBOLT »
NorWeWa
Re: speedo
« Reply #3 on: May 28, 2023, 03:27:19 PM »
In the Downtown 300i manual, there is a nice wiring diagram. German language "schaltplan Downtown 300i" if you open this should help with thw correct color codes connections.     https://kymco.at/kymco_store_view/dowloads/kymco.html
Art
Kymco Symco
Re: speedo
« Reply #4 on: May 28, 2023, 05:55:29 PM »
Art
wiring diagram doesn't help....it shows  two blade connectors one on front one on rear....mine has both on rear.....has anyone a photo of the coil on the scooter ?
Re: speedo
« Reply #5 on: May 28, 2023, 08:17:53 PM »
Don't have a picture but do you have a multimeter with an ohms scale or two?
Kymco Symco
Re: speedo
« Reply #6 on: May 28, 2023, 08:40:27 PM »
have a multimetre yes
NorWeWa
Re: speedo
« Reply #7 on: May 28, 2023, 11:21:39 PM »
   Got a photo,  but color didn't come out good.  Looking at the coil, it does have both connectors on the end .  The bottom one is green, and the one on the top is black, when looking at the photo.
Kymco Symco
Re: speedo
« Reply #8 on: May 29, 2023, 05:31:02 AM »
huge thanks....just what i needed to see......seems the last person put the wires the wrong way round on mine
Re: speedo
« Reply #9 on: May 29, 2023, 10:50:12 AM »
Plug wire to green = high ohms
Plug wire to black =  high ohms
Black to green        = low ohms
NorWeWa
Re: speedo
« Reply #10 on: May 29, 2023, 01:50:17 PM »
And the manual does have section to check the coil using a voltmeter.  I sure do like how the Kymco Downtown 300 is reasonable to access and work on. Plus it's just a great running scooter. Makes me think the AK550 must be a very good Maxi.  Way more than I need.
Art
Kymco Symco
Re: speedo
« Reply #11 on: May 30, 2023, 07:24:41 AM »
thanks...did the check for the ignition coil with info from manual. all checked out
so only thing wrong it was wired wrong
Re: speedo
« Reply #12 on: May 30, 2023, 04:42:21 PM »
Great! We can add that to the list of items NOT IN the service manual that keeps these from starting!
Kymco Symco
Re: speedo
« Reply #13 on: May 30, 2023, 07:02:18 PM »
yep.....when i get free time i will be looking at the crank sensor next
