Author Topic: AK550 Grooved Rotor  (Read 688 times)
omacoder
AK550 Grooved Rotor
« on: June 02, 2023, 07:14:46 PM »
Hi gurus- this rear rotor has generated a scrape/groove on the inside closest to the wheel.
When I rotate the tire I can hear a very light scrape during a portion of the rotation.
Service shop is booked until the end of June.
Is this something of concern? Something that I can repair myself?
The bike has 3500 miles on it
Appreciate your input!!
https://photos.app.goo.gl/iUX1bBr1A8vTVrUN6
« Last Edit: June 02, 2023, 07:28:27 PM by omacoder »
Re: AK550 Grooved Rotor
« Reply #1 on: June 02, 2023, 07:44:57 PM »
3,500 miles?
Fingernail across the disc - do you feel any significant "grooves'?
No?
In your photo I see nothing unusual....looks like normal marks from normal pad/disc contact.
« Last Edit: June 02, 2023, 07:47:04 PM by Stig / Major Tom »
« Reply #2 on: June 02, 2023, 08:45:44 PM »
All rotors will develop some grooves over time. There is no repairing, only replacing, but that looks fine, I wouldn’t worry about it.
  • Central Iowa
« Reply #3 on: June 02, 2023, 09:45:17 PM »
Looks like a normal rotor to me.
How are your brake pads?
Do you use the parking brake much or have you left it on after forgetting to take it off?
Here is the inside and outside of my AK 550 rotor after more than 9350 miles:
https://photos.app.goo.gl/j6SzuXSt3vNAEK3m9
No significant groves felt when running my finger nail over the surface.
The brake pads on mine look like they are barely worn... still a thick amount of pad material on the backing.
I did get a set of rear pads and plan to get a set of front pads (both sides) just to have on hand but don't expect to need them for a few years based on current wear.
« Last Edit: June 02, 2023, 09:48:14 PM by rjs987 »
omacoder
« Reply #4 on: June 02, 2023, 10:43:54 PM »
Sounds good, thank you. I didn't think there should be rough ridges in the disc and thought it was maybe caused by calipers needing adjusted or something, but since there's not too much of a noise that it makes with a rotation it must be just bad enough to dig into the disc.
I will check the break pads, thanks for the tip!!
I don't believe the parking break was ever left on, on accident. But that's a good thought. Thanks!
omacoder
« Reply #5 on: June 02, 2023, 10:44:42 PM »
Ok phew! Sounds good. Thank you! :a)
NorWeWa
« Reply #6 on: June 03, 2023, 01:03:02 AM »
If it's still making noise, I would pull the pads out and check for any embedded rock or bit of metal.
« Reply #7 on: June 03, 2023, 04:28:17 PM »
Art beat me to it Brian.  All disc /pad combos collect some road dust & grit in there, I guess that's what causes the grooves.  Looking at the photo I'd also say nothing to concern yourself over.
By the way, welcome to the forum!
