Author Topic: Help needed! Spark plug wire/coil  (Read 295 times)
Garym0510
« on: June 11, 2023, 03:40:42 AM »
2012 kymco people gt 200i
Spark plug coil and wire will any 12v coil and 90 degree two pin Connector work or does it need to be kymco oem.
My issue is im selling the bike this week and low and behold the wire or the coil kicked the bucket on my last plug change the plug wire inside metal came out while pulling it from the spark plug I shoved it back in and it's been running fine but tonight it died when idling.
Re: Help needed! Spark plug wire/coil
« Reply #1 on: June 11, 2023, 11:56:31 AM »
Would think any would work.
The sparkplug boots screw off usually. Trim a small bit of the wire off then screw a new one on.
Yeah, these things can break in there at the connector on scooters.
