I am testing a 2022 with 1000 miles do they have 2 key bobs ? What else should I look for ? Or ask ?
Thanks Tom
It SHOULD have 2 key fobs. Something to verify. And the owner manual.
Really just be looking at the same stuff as on any other motorcycle/scooter. Fluids changed, tire wear (really shouldn't need those since only 1000 miles), general condition of the plastics fit and finish should be good. Check brake pads... especially the rear pads to make sure the previous owner didn't try to ride it with the parking brake engaged. The brake pads should be easy to see using just a flashlight. Check that the heated grips work. To turn those on you have to hold the heated grips button on top the left control cluster for a few seconds then tap that button to toggle through the heat settings, low/medium/high. For only 1000 miles the AK should look and work like new.
If you go for it be sure to download/install the Noodoe phone app to link to the bike. Even if you don't use the Noodoe navigation that will keep the clock up to date/time. The only subscription bit is with the navigation maps. That is a 3 year subscription with the first 3 years free. I found out the entire USA maps are $17 which is really a bargain. At least last time I looked it was that. But other stuff on Noodoe has no subscription that I am aware of.
Yes, the factory warranty is 2 years from date originally sold. Don't remember if transferable to a new owner but would be surprised if not. I bought mine in Nov 2021 so my warranty is up in the fall.
