Author Topic: Like 150i, Givi Windshield Arrived, problems (with pictures)  (Read 537 times)
lewtwo
    • My Kymco Like 150i ABS web page
Well the Givi Windshield finally arrived from Italy. Having some mounting problems. Seems the bikes in Roma do not have US turn signals. The uprights also appear to stand at a oddball angle :(
I loosened all the mounting hardware on the uprights and attached the windshield to see if that would help with spacing. No joy yet. I may be forced to to make some custom spacers or something. I wonder if the 150i master cylinders could be larger that the ones for the earlier Like 125 and Like 150II models.
It is still over 90 degrees outside so I decided to take a cool down break.
« Last Edit: June 21, 2023, 02:17:24 PM by lewtwo »
The more I learn the more obvious the immensity of my ignorance becomes.
https://www.keywild.com/scooter/Kymco150i/
Re: Like 150i, Givi Windshield Arrived, problems
« Reply #1 on: June 21, 2023, 11:39:43 AM »
Photos of your issues?
Turn pods interfering with wind screens is also an issue with some screens and newer Vespas.
Vespa/Piaggio have kits to delete the USA turn pods....lighting the signals in the front leg shield....as seen outside the US.
lewtwo
« Reply #2 on: June 21, 2023, 12:11:01 PM »
After my cool down break I took another go at it.
I have it mounted now but I digressed a bit from the GIVI instructions to get a better fit.
I now need to go back and look at it in the daylight.
Light was not advantageous for taking pictures at midnight  :(
lewtwo
Re: Like 150i, Givi Windshield Arrived, Pictures
« Reply #3 on: June 21, 2023, 02:16:35 PM »
Modifications to the Givi instructions:
1) I used the US turn Signal pods in place of the Givi spacer to attach the upright bracket to the bottom of the brake master cylinder. Those pods have a stem that is 5 to 6 mm shorter than the Givi Spacer. The pod stem has a tab that aligns the turn signal to the master cylinder. Thus a spacer can not be used between the top of the stem and bottom of the master cylinder.
2) I installed the windshield to the left and right upright brackets. I snugged those fasteners down but with just a tad free movement. All the other fasteners were left lose. Then I tugged, twisted, slid and otherwise manhandled the windshield into what seemed the best alignment. Then I tightened all fasteners in place.
Repeat step 2 as required ....  :-\
I still need to go back and make some fine adjustments and lock-tite (blue) everything into place. The windshield is a a bit taller than I had hoped. The seems to be just a bit higher than my helmet. I may go back later and trim 150 to 250 inches mm off the top. I am not overly impressed with Givi's solution for the mirror mounts. I will post high res pictures to my web site later today. This old fart needs to take his morning nap.
Update:
high res photos now posted
https://www.keywild.com/scooter/Kymco150i/Windshield/
The "other" sub-folder contains additional raw images that I have not processed.
« Last Edit: June 21, 2023, 04:27:49 PM by lewtwo »
Ex-KLR
  • Cumberland County Tennesee
Re: Like 150i, Givi Windshield Arrived, problems (with pictures)
« Reply #4 on: June 21, 2023, 03:49:56 PM »
I bought this from Amazon for my Like 150i. Works well.
« Last Edit: June 21, 2023, 04:14:46 PM by Ex-KLR »
Like 150i ABS
lewtwo
« Reply #5 on: June 21, 2023, 04:06:39 PM »
I installed this on my Like 150i with no trouble.  Works well.
https://www.amazon.com/gp/product/B00T6JK3YE/ref
Looks interesting but I have now have time and money in the GIVI ... I am gonna make it work !
I got the Givi because of the name brand (foolish) and it was the only one specifically design to fir round the unusual shaped headlight. I think that I want to apply some 'tinting' to the back side as well. Also thinking about adding Cell phone and GPS holders.
lewtwo
« Reply #6 on: June 21, 2023, 04:10:13 PM »
The pods are below the windshield ... but just barely. I believe the practical solution here may be to 'adjust' the angle on the OEM signal mounts down a bit ... perhaps a 30 degree angle.
« Reply #7 on: June 21, 2023, 04:14:16 PM »
Agreed - all these screen mounts which rely on using the mirror mounts look awkward!
But, they do raise the mirror from its stock position - which a lot of riders need to improve their rear vision in the mirrors.
I like how Piaggio welds a mount for screens onto the handle bars. It's in there, if you need it. Makes for a clean installation.
« Last Edit: June 21, 2023, 04:21:24 PM by Stig / Major Tom »
GoVanGo
« Reply #8 on: June 24, 2023, 04:47:01 PM »
I had to do some crazy extender , spacers dancing to get a shield on my Agility 125.
06 ZX50
14 Agility 125
17  Like 200i
Before scoot life .
Honda XR100, 4 CB 750s , 1978 Kawa Z1R , 79 Goldwing , HD RoadKing , Honda Areo 1100 .
GoVanGo
« Reply #9 on: June 26, 2023, 02:23:28 AM »
Heres it on the Agility
And 2 hex bolts and transplanted to my Like today.
« Last Edit: June 26, 2023, 02:25:09 AM by GoVanGo »
06 ZX50
14 Agility 125
17  Like 200i
Before scoot life .
