Author Topic: Changing rotors to my downtown 350  (Read 908 times)
Yoni159
« on: June 23, 2023, 03:57:51 AM »
I must to use locktight when i am changing my rotors? And where to apply this only on the rotors bolts? On also on the callipers? And i must use tourqe wrench?
Re: Changing rotors to my downtown 350
« Reply #1 on: June 23, 2023, 08:41:17 PM »
@Yoni159 welcome here!
On rotors and breakcaliper bolts its adviseable to use blue @Loctite because of vibrations on this items.
Torque wrench not necessarely if you have some experience with tools.
Yoni159
« Reply #2 on: June 24, 2023, 04:36:59 AM »
so how to tighten the bolts without tourqe wrench? 35nm is really tight?
« Reply #3 on: June 24, 2023, 06:32:17 PM »
What I said, if you have some experience, NO torque wrench.
If not, the likelyhood to mess up bolts or treads is high with torque wrench.
(for torque figures pls see pic)
« Last Edit: June 24, 2023, 06:35:32 PM by Ruffus »
stuo
« Reply #4 on: June 24, 2023, 07:35:51 PM »
A tip: If the rotor machine screws are difficult to remove due to the locktite, apply heat to the screw heads with a propane torch for a few seconds and they should easily break loose.
I agree with Rufus: snug them up without using a torque wrench unless you are not a confident "wrencher". The locktite will be your insurance.
2009 GV 250
