Author Topic: Swapping "restricted" 2011 ECU for 2009 ECU for performance gain  (Read 1640 times)
Ericson
Hi !
I have 2011 DT 300i which has power rating of 29 vs 33 hp on 2009 model due to emissions restriction. I can get my hands on used 2009 model ECU for about 50 USD. I checked parts catalogs for pre-2011 and aft-2011 models and internal engine parts have the same numbers ( piston, head, etc ). Throttle body assembly also shares similar part number between "new" and "old" power rating.
2011 model uses 39200-LEA7-E05 ECU while 2009 model uses 39200-LEA7-E00 ECU.
So I came up with idea of swapping ECUs and see what happens. What do you guys think ?
« Last Edit: June 29, 2023, 08:11:08 AM by Ericson »
Re: Swapping "restricted" 2011 ECU for 2009 ECU for performance gain
« Reply #1 on: June 29, 2023, 11:04:21 AM »
Hi !
Worth a try!
Kymco Symco
« Reply #2 on: June 29, 2023, 06:55:25 PM »
for that small amount of money i would buy it  & try it....can' do any harm
Ericson
« Reply #3 on: October 02, 2023, 06:37:33 PM »
Hi !
I wanted to report that swapping ECU is the way to go if you are having issues with mid throttle hesitation or "micro-pulls" with post 2011 ECU's. That was the main reason why I deceided to swap ECUs. I tried to rotate MAF sensor before but that didn't help. I made now 3000 km with "new old" ECU and I'm so sure that I will never go back to 2011 restricted ECU so I sold it 8)
Engine is pulling forward constantly no matter how wide I open the throttle. I can't feel any additional HP or torque. ( 2009 33 hp vs 2011 29 hp ).  My fuel MPG went down from 75 to 71.
« Last Edit: October 03, 2023, 07:46:49 AM by Ericson »
izmircephastanesi
« Reply #4 on: January 22, 2024, 03:16:39 PM »
Hi !
how can i find 2009 ECU?
« Reply #5 on: January 24, 2024, 06:21:30 PM »
Ebay - or national motorcycle recycle yards?
JJJoseph
  • Kymco Sento
« Reply #6 on: March 11, 2024, 08:51:18 AM »
Do you have the Kymco part #?  Just plunk it into your browser search and sources will pop up like magic.
