Author Topic: How To Change Dash Display Question  (Read 371 times)
Aufgeblassen
« on: July 03, 2023, 06:10:41 PM »
I just got a new Like 150i, and I am able to toggle between miles and kilometers on the odometer, but how do I switch to Fahrenheit from Celsius?
lewtwo
    • My Kymco Like 150i ABS web page
Re: How To Change Dash Display Question
« Reply #1 on: July 03, 2023, 07:22:19 PM »
Good question. It is not covered in either the owner's manual or the service manual. I just went downstairs and checked mine. It reads in "Fahrenheit" (regardless of if ODO is reading miles or kilometers).
By the way I like the color of you machine and I would love to be able to order that rear rack. What is the year and "Model Number" of you bike? Hint the only place that you will find the model number on the bike (and probably the paper work as well) is on that sticker at the bottom right of you ride. Make a note of it for later reference.
The more I learn the more obvious the immensity of my ignorance becomes.
https://www.keywild.com/scooter/Kymco150i/
Aufgeblassen
« Reply #2 on: July 03, 2023, 07:58:47 PM »
That's weird!  Mine is a '23 Life 150i, and only reads in Celcius!
stuo
« Reply #3 on: July 03, 2023, 08:47:09 PM »
An easy approximate way to convert Celsius to Fahrenheit: double C and add 25. Example: 30 degrees Celsius X 2= 60, add 25= 85F.
The accurate conversion formula is  9/5 X C+32= F   So: 30 X 9/5=54, plus 32= 86F exactly.
As C climbs higher than 30, or drops below 30, the approximation formula is less accurate but close enough for government work, as they say.
2009 GV 250
Aufgeblassen
« Reply #4 on: July 03, 2023, 11:41:37 PM »
I prefer it display correctly.
Aufgeblassen
« Reply #5 on: July 04, 2023, 10:52:40 PM »
I somehow got the temp. display to F when I was trying to reset Trip 1.
