Author Topic: Anti Seize on Bolts?  (Read 1626 times)
Vision
« on: July 06, 2023, 03:09:59 PM »
I removed the exhaust yesterday and the upper bolt attaching it to the frame was way too hard to get off. It looked ok but I'm concerned for the future of taking it off and on. Is putting some anti seize on it next time a good idea? Is there a better option?
sparko
Re: Anti Seize on Bolts?
« Reply #1 on: July 06, 2023, 03:52:43 PM »
Heres a great video. Grease works great, looks like permatex is best for anti seize but all the products tested had their strong points. He fills up a lawn mower crankcase with aluminum based anti seize to check for seize. grease is adequate I think for your problem. pull out your dipstick and dab it on the bolt.
« Reply #2 on: July 06, 2023, 05:29:44 PM »
Yes.
I use the copper....
« Reply #3 on: July 07, 2023, 08:14:53 AM »
Never had an issue using coppaslip, the copper based grease.
« Reply #4 on: July 07, 2023, 10:44:29 AM »
Copper paste or white ceramic mounting paste.
« Last Edit: July 07, 2023, 10:46:37 AM by Ruffus »
« Reply #5 on: July 07, 2023, 01:50:01 PM »
Works well but be careful with torque. Torque limits are reduced due to the lubrication. MUCH EASIER to strip threads especially in aluminum.
Vision
« Reply #6 on: July 07, 2023, 03:23:16 PM »
FYI, from what I'm reading it doesn't look like a good idea to use copper anti seize on aluminum.
JJJoseph
  • Kymco Sento
« Reply #7 on: September 18, 2023, 05:46:44 AM »
The exhaust studs are steel, and the exhaust acorn nuts are bronze.  Anti-seize is essential since the exhaust attach is "red hot" under the floor, in the rain and mud.
« Reply #8 on: September 18, 2023, 11:27:50 AM »
Not all of those acorns are bronze...also, he's talking about muffler to frame mounting bolt -- not exhaust studs.
And, will do some reading about copper paste on aluminum....thanks vision!
« Reply #9 on: September 18, 2023, 11:54:57 AM »
Go with what CROSSBOLT writes.
To avoid corrosion and torque trouble use ceramic mounting paste on such places.
In certain conditions (alu/ salty road or seasides) I saw coperpaste contraproductive on aluminium (the purer alu the more electrical eating off) parts.
JJJoseph
  • Kymco Sento
« Reply #10 on: September 19, 2023, 08:31:35 PM »
Good idea! You'll find copper anti-seize works just fine.  However you won't be able to remove the exhaust without also removing the acorn nuts. Regardless, a little reading on the topic is always useful, and I always encourage it.
