Author Topic: How do I get to the spark plug? 2008 125cc  (Read 689 times)
GL4202
« on: July 22, 2023, 09:27:14 PM »
I need to replace the spark plug and got the correct one, but I need to get into it and the owners manual wasnt much help
« Last Edit: July 22, 2023, 09:31:13 PM by GL4202 »
Re: How do I get to the spark plug? 2008 125cc
« Reply #1 on: July 23, 2023, 09:12:13 AM »
@GL4202 welcome here!
Do change your sparkplug are two ways to approach it:
- underseat bucket out and you see down there on the scoots LH motorside a sparkplug cap with a cable attached to
- pry off this cap, take a proper sparkplug spanner and get her out
- second approach, if you are willing you lay down close to your scoot
- scoot on mainstand, look from beneath at mentioned cap, get it out
Maybe you go to Youtube and watch some videos on this subject
Feel free to ask further, good luck!
« Last Edit: July 23, 2023, 09:13:52 AM by Ruffus »
Vision
« Reply #2 on: July 23, 2023, 09:57:11 AM »
Remove the seat bucket (4 bolts, 1 screw) and you'll see the spark plug wire/cap on the forward, right side area. Pop the cap off and use a spark plug socket and ratchet to remove/replace.  To seat it properly when installing be easy and hand thread the plug before using the ratchet.
GL4202
« Reply #3 on: July 24, 2023, 08:15:03 PM »
Thank you guys
