Author Topic: Rear end blown??? Need help!  (Read 1066 times)
Kashmoney05
« on: July 30, 2023, 07:49:17 PM »
So I think the rear end is blown. It makes a loud popping noise like it’s skipping a tooth. When it is on jackstands and you accelerate it doesn’t make the sound. When one on the ground and you accelerate it makes a loud popping noise. Any kind of advice or suggestions would greatly be appreciated. Thank you
Attached is the YouTube video clip I made for it
Re: Rear end blown??? Need help!
« Reply #1 on: July 31, 2023, 12:17:30 AM »
check the running gear attachments to the frame, I had similar symptoms, but in front, when I was in 4wd backing up. My frame was broken and running gear was pulling away and skipping.
I had frame welded and gusseted,  I've beat the crap out of mine, logging, but I think what did the damage, was snow plowing, hitting frozen rock solid snowbanks in frigid temps
