assembled my first motorcycle fork this afternoon. I removed both forks from my Nighthawk and was able to get the big circlip out of one fork, which allowed oil seal removal and complete disassembly. The left fork's circlip was rusted solid in there..I soaked it for about a week in various chemicals, mostly PB Blaster. I was finally able to get the clip to move enough yesterday to get a small flat blade screwdriver in there to get the clip out. It felt like victory!
The dust seal was torn and water had obviously gotten in there and rusted the thick, metal circlip.
I used #0000 steel wool to clean the chrome fork tube of any rust specs and assembled the fork with new oil seal, washer, dust seal, 2 bushes and new copper sealing gasket for bottom bolt. Filled it with 15.3 oz of new fork oil, pumped it a bunch of times and it's good to go!
Felt great to have one fork done.
Waiting to do the next fork until my washer comes in. The big washer that sits under the oil seal can also be used to help drive in the seal from above when using a 1.5" pvc pipe. I used the washer from the 2nd fork to drive in the oil seal in the first fork but now I need the spare washer to assemble the 2nd fork, if that makes sense.
I used all new Honda parts for the rebuild. When both forks are done I'll move on to the calipers, brake lines and both brake and clutch masters. I want to disassemble the calipers before ordering parts as I'm not sure if I'll need new pistons or not. I'm thinking not, but I'll know more when I take them apart.
Pic of victorious first fork and old parts that were replaced.
