Author Topic: will 15mm 12mm rollers work  (Read 1448 times)
nut
« on: December 12, 2010, 06:29:29 PM »
I was given a set of 5g rollers but there 15mm by12mm. N the stoke size is 16mm by 13mm if. I use the smaller size will it work r would it be like the worn out stoke ones rwould it make it a little better mine have 26000kl on them so figured they probly about the size of the smaller ones but the 15mm ones r lighter just wanted to know if it b worth the time in puting them in tell I can get the 16mm ligh weight on
Rianna
Re: will 15mm 12mm rollers work
« Reply #1 on: December 13, 2010, 02:27:26 AM »
??? So you have 16 x 13's in and they're getting old...but you wanna put the 15 x 12's in instead of the 16 x 13's...until you can get some 16 x 13's?
Did I read that right?
glopezz05
« Reply #2 on: December 13, 2010, 03:37:41 AM »
Yeah...
Um...
Well, the new rollers will fit, they're smaller than stock but...
I'd guess you'd have two main problems.
First would be a vibration/rattle. The smaller size would mean they have more room to bounce around.
My other guess would be that they would wear out faster, but that's just a guess.
I think the new, more rounded, weights would act smoother than your stocks due to no flat spots.
Im usually on a bicycle, so for me, this thing is hauling ass!
oswaldters
« Reply #3 on: December 13, 2010, 03:42:16 AM »
Can't say I've ever heard of anyone trying that.
I wouldn't want to be the one that tests it out to see how it goes.
New rollers are cheap enough that I would wait and get the right ones.
glopezz05
« Reply #4 on: December 13, 2010, 02:34:02 PM »
I agree.
