Did you miss your
activation email
Scooters - 125 to 300
People s200
shifting problem
Topic: shifting problem (Read 4054 times)
brianmckewen
Newbie
shifting problem
August 21, 2023, 02:57:57 PM »
Hi everyone. My problem is that up to 50 mph indicated all is fine with shifting but at 50 mph indicated the bike stops accelerating. It will not shift to a higher speed unless I reach 50 and then back off the gas a bit and then the tranny will shift so that my speed increases. Is this the clutch drive faces not moving properly? I have not had this problem in the past and have just noticed it. Have not changed anything for a few years and then all I did was to lighten my roller weights a bit. Thanks for any input. Brian.
2009 Kymco People S200
2022 Honda Navi
2022 Honda ADV 150
Eastern Iowa, USA
Re: shifting problem
August 21, 2023, 03:34:04 PM »
I'd want to pull the cvt cover and look at everything..is belt old? Everything functioning properly? Another option would be the carb and fuel delivery...but pretty unlikely that the main jet clogged, those are big and hard to clog up.
brianmckewen
Newbie
August 21, 2023, 07:41:32 PM »
I will take a look but it is not fuel or carb. As long as i keep throttle to go fifty it does not shift any more until I let off the throttle. Then I will hear the engine slow down a bit as the tranny shifts and ipeed goes up to about 64 indicated. Same thing every time. Think the plates on the back end are not moving until I let off the throttle a bit? Belt new. Carb new. Contra spring weak over the the years maybe?
2022 Honda Navi
2022 Honda ADV 150
Back
