Author Topic: Kymco People 150 "Backfire"?  (Read 306 times)
dwarnimont
« on: August 25, 2023, 02:40:37 PM »
My scooter has recently started to have a faint "backfire".  It's more like an almost backfire with a poof or subtle puff not ending the a real pop like cars.  I replaced the carb and it's the same.  What area of the engine should I be investigating?  Someone said the timing may be off. If this is a real thing, where can if find information to help me improve timing?
Thanks, Dave
Re: Kymco People 150 "Backfire"?
« Reply #1 on: August 25, 2023, 02:57:30 PM »
@dwarnimont welcome here!
Give some more info why you changed the carb, some more data about your scoot, please.
-was your cylinderhead off?
-did you tap your valves correctely?
-this puffing COULD be caused by some false air entering between carb and cylinder head, means your manifold there is sucking in
-or either to lean or too rich fuel mix
-how does your sparkplug electrode look like after a short drive, greasy or white/ brownish
-guess you renewed your airfilter, sparkplug and cap?
Check all this and maybe give us a feedback.
« Last Edit: August 25, 2023, 03:04:27 PM by Ruffus »
