Author Topic: Starting issue got worse  (Read 7064 times)
SiRen8
Re: Starting issue got worse
« Reply #15 on: September 23, 2023, 01:59:09 PM »
Thanks Ruffus, this is really useful info  ;)
SiRen8
« Reply #16 on: September 27, 2023, 12:28:45 PM »
Hi Ruffus,
I've now split the engine so I can see the starter clutch etc. Could you explain to me how this item works as the large cog which spins the engine is loose and move able? I thought the starter clutch was all one piece?
Many thanks
S
« Reply #17 on: September 27, 2023, 07:49:45 PM »
Here we go:
- starter clutch IS one piece, but has to be driven by something too (pls see pic when dismantled)
- the other pic shows you (arrow) where the starter sprocked grips in
- further down chain and drive for oilpump
BTW: watch out, this big special 4- pronged nut has LH tread
« Last Edit: September 27, 2023, 07:51:36 PM by Ruffus »
SiRen8
« Reply #18 on: September 28, 2023, 08:18:44 AM »
Here we go:
icant see any pics?
SiRen8
« Reply #19 on: September 28, 2023, 09:31:53 AM »
Ok i can now see the pics and all looks the same other than i havent yet removed the castle nut to release the starter clutch. I think the Starter Clutch is broken but wont know until i remove it. Is there a pin or something that locks that castle nut?
« Reply #20 on: September 28, 2023, 10:43:26 AM »
No, no pin nothing, only this nut has LH tread!!
Means to unlock, turn it CLOCKWISE.
SiRen8
« Reply #21 on: September 28, 2023, 12:38:07 PM »
Ok ive ordered a special tool to remove the Castle Nut. its a pity i cant post pics as it says they're to big...
« Reply #22 on: September 28, 2023, 02:02:05 PM »
In case you don't get this tool, it can easily made from a fitting socket using a small flex to cut it out.
For pics: take pics with your smartphone
- minimize them with an downloaded app
- put them in your script
SiRen8
« Reply #23 on: October 04, 2023, 11:25:15 AM »
Castle Nut Tool wasn't long enough
« Reply #24 on: October 04, 2023, 11:48:24 AM »
This "castle-nut" is easily to be opened(clockwise) with a chisel and hammer, once unlocked thenwith pliers. Don't worry about a few schratches on this nut.
SiRen8
« Reply #25 on: October 10, 2023, 11:59:56 AM »
Removed the castle nut and then the drive cog, the starter clutch was attached by 3 Allan key screws. One of them was really loose and has been rubbing the back of the cog....
« Reply #26 on: October 10, 2023, 03:21:31 PM »
...degrease, check sprockets for mechanical faults and back in again. LOCTITE for hydaulic is used on this allen key nuts.
SiRen8
« Reply #27 on: October 10, 2023, 06:48:23 PM »
Should I get a new starter clutch etc just incase?
« Reply #28 on: October 10, 2023, 08:02:42 PM »
Yes, would be good, BUT will highly depend on
a) availabilty ???
b) price at US ?
Here in Italy I would not hesitate a second.
(pls see pic)
« Last Edit: October 10, 2023, 08:08:45 PM by Ruffus »
JJJoseph
  • Kymco Sento
« Reply #29 on: December 05, 2023, 04:16:06 AM »
a) availabilty ???
b) price at US ?
These parts are also shared with smaller Kawasaki ATVs. I use Kawasaki parts routinely.  The Kawasaki parts people are clueless about the interchange codes so you have to do some of your own legwork.  But the parts come in a Kymco package with a Kawasaki label attached. Note the attached photo is just an example, not the part you're seeking.
