Author Topic: Max rpm is 5000  (Read 9881 times)
Rickster
Max rpm is 5000
« on: September 16, 2023, 03:58:51 PM »
My B&W 150 wont accelerate above 5000 rpm. The throttle cable is correctly adjusted. I replaced the 13g rollers with 11.5g rollers and still no difference. The belt is new. The spark plug is new. I put new premium gasoline in it.  Suggestions?
I read some other threads and will look into possible vacuum leaks - lines, intake manifold, diaphragm. thx.
« Last Edit: September 16, 2023, 05:05:34 PM by Rickster »
2007 B&W 150
2010 Yager 200i
Re: Max rpm is 5000
« Reply #1 on: September 16, 2023, 07:07:50 PM »
As said, I think your scoot is still suffering from TDC off, means your timing is not spot on.
