Author Topic: Idle and air mixture adjustment for People 50  (Read 2297 times)
Amberturd
« on: September 18, 2023, 12:33:03 PM »
Hello,
I have recently bought my People 50, previous owner messed up with carbs idle and air mixture and now I do not have base line for adjustment. Does anyone know if I twist both screws all the way in, how many turns out should i do for it to be optimal.
Thank You
Re: Idle and air mixture adjustment for People 50
« Reply #1 on: September 18, 2023, 08:14:42 PM »
Welcome here!
Usually carefully all the way in, then 2 1/2 turns out again for a start. Try it to make it running.
- fuel mix in or out until HIGHEST revvs
- idle screw fixes revvs about 1800rpm
Check whether this little washer and O- ring are in front of spring.
Each motor is a little bit different, depending on age, use and several other parameters.
