Author Topic: My lil" red demon  (Read 33041 times)
billbow45
Re: My lil" red demon
« Reply #30 on: June 10, 2011, 01:13:13 AM »
where did you buy the suitai cdi box and what was the price. thanks
thebatman
« Reply #31 on: June 10, 2011, 06:10:13 PM »
If u dont mind me asking I want to stretch my zx and lower it how did u fabricate the rear extention ? Would love some pics!!!
Hey man, sorry for the long delay here... I actually had a oem bracket extended.. I do have a pic somewhere, i'll see if i can find it and post again..(i think it's in the pics of the parts already posted...
Hey man, the suitai cdi comes from suitai themselves and its priceier than the others but i seem to be happy with it. they are around $75 thrugh them... S.A was selling an exact match at one time i know
"THE BAT"MAN...
Says:
Pattyboi33
« Reply #32 on: June 10, 2011, 09:46:12 PM »
Sorry but. Didn't see it when ever u can post another pic is cool thank you :)
thebatman
« Reply #33 on: June 19, 2011, 01:12:14 AM »
I need some carb fine tuning help... Any carb ppl around? oko carb?
"THE BAT"MAN...
Says:
thebatman
« Reply #34 on: June 20, 2011, 11:10:42 AM »
 ??? ???  I feel ya, they are a pain in the ass for sure.... :D
"THE BAT"MAN...
Says:
sidthesloth
  • Kymco ZX50
« Reply #35 on: June 20, 2011, 11:22:01 AM »
Sorry, can't help you there mate, I am in about the same boat. I seem to be rich at low speed, but not at wot. Might need to lower my needle, but, a 38 pilot and 120 main, I am already at the second lowest setting, won't start when cold without the choke. My intro to carb tuning is a bit frustrating.
thebatman
« Reply #36 on: June 20, 2011, 11:47:50 AM »
Amen brother...... :)
I tried a 38 and she ran like straight ass WHEN i got her started, i installed a 45 to try it out... i wonder if alot is the needle now
"THE BAT"MAN...
Says:
sidthesloth
  • Kymco ZX50
« Reply #37 on: June 20, 2011, 12:01:21 PM »
While I was running 3/4 throttle it was ok, now that I have raised the gearing with the belt and weights, around town am only using lower throttle openings, it is too rich, haven't done any adjustments today.
thebatman
« Reply #38 on: June 21, 2011, 11:16:53 AM »
I may be on to something here with the carb..... thanks mainly due to "SHAKA"...... installed a 120mj,45pj, needle in the 2nd slot, mix screw 1 turn out... Seems i have more rpm, more top speed now at only 1/3 throttle, topend is still flat, gonna slap in a 115mj and see what that'll bring
"THE BAT"MAN...
Says:
sidthesloth
  • Kymco ZX50
« Reply #39 on: June 21, 2011, 12:30:38 PM »
Do you find that you lose a lot of throttle smoothness with the needle in the second lowest setting? With mine it has a point of almost nothing then almost screaming.
thebatman
« Reply #40 on: June 21, 2011, 09:40:25 PM »
Actualy no, i still had spit/spudder at certain rpm with the needle in the 3rd slot, shaka talked me into swapping the 120, then bam went to crap, lowered the needle and now more rpm/power.. I'm liking this so far, didnt get a chance to try a 115 today, stormed again for a bit.
"THE BAT"MAN...
Says:
thebatman
« Reply #41 on: August 28, 2011, 12:35:15 AM »
Well guys, i haven't updated this in awhile so i figure now is a good time...
A while back i had a "major meltdown" on my very own "suckubus". A c-clip had came out of the piston and just disappeared. I thought it destoyed my crank bearings. I took the engine apart and to my amazement seen the piston looking good. I removed the head and discovered that the c-clip was missing, hence the failed bearings. The wrist pin had made it's way out to RUB the cylinder wall REAL GOOD. A nasty groove all the way...bbk shot in the ass...
SO.... I FINALLY decided to put back together oem modded again. I took the oem cyl and started porting the transfers and boost...
NOthing done.....
I got all the porting done and now was the time to split the cases to swap the bearings.. Little did i know it WASN'T the bearings that failed on me..... :'(
My dam crank BROKE. A nice clean break too i might add.. I was not expecting that one there. :o
Bearings seem to be good still.. ??? :D
That was real heart breaking to see that when i was all ready to exchange bearings. HOLY BREAKDOWN BATMAN!!!  I guess a tuners saying of "if it ain't broke, you obiously haven't tuned it enough" rings so dam true about now.... :D ;) Thanks for the words luke. ;)
Just goes to show the ABUSE a kymco can handle. ;)
"THE BAT"MAN...
Says:
sidthesloth
  • Kymco ZX50
re: giving the engine gas after kick start kills it
« Reply #42 on: August 28, 2011, 02:07:22 AM »
Damn that sucks, how the hell does a crank break? Who did you buy the crank from?
Good luck with the rebuild.
thebatman
« Reply #43 on: August 28, 2011, 03:44:42 AM »
IDK, id like to know how it happened.... ???
It was the oem crank thankfully.. ::)
"THE BAT"MAN...
Says:
sidthesloth
  • Kymco ZX50
« Reply #44 on: August 30, 2011, 08:46:29 PM »
I just saw the pics, did you have a rear wheel seize to cause the break? or was it "just one of those things"?
I paid $110 for the stroker crank, you can get what I think he calls a reinforced stock crank for about $78. I will have a look and see if I can find a link.
